Post your keyboard/keycaps!
Fkazim
16 Apr 2020, 13:41
Sturmtiger001 wrote: 16 Apr 2020, 06:27 It isn't much, but everybody has to start from somewhere excluding the k70 lux I have upstairs somewhere. (hoping to add to the collection very soon)
Looking good. I like the red esc key :D I will be doing a similar thing for my AT soon.
kmnov2017
16 Apr 2020, 18:56
Here's my F122 that I recently restored....
kmnov2017
16 Apr 2020, 18:59
And an F AT...modded to an F77 layout
kmnov2017
16 Apr 2020, 19:23
And my beloved beamer...!!!!
kelvinhall05
16 Apr 2020, 19:31
Nice boards, sell them on reddit for $6000 profit!
Sturmtiger001
17 Apr 2020, 02:18
kmnov2017 wrote: 16 Apr 2020, 18:56 Here's my F122 that I recently restored....
Holy moly your collection is insane, they're all lovely keyboards. I'm awestruck at this point, especially with that f122, like wow!
sharpjimbo
18 Apr 2020, 17:28
Hi all,
My HHKB with Domikey Cherry style doubleshot ABS keycaps. Enjoying these keycaps, their profile follows the original HHKB keycaps, but they're just a tiny bit higher.
20 Apr 2020, 18:26
And you're off to a great start, in spite what some people might think. :D
mcmaxmcmc
21 Apr 2020, 12:17
Some gravure photos of my French Canadian Apple boards :D
codemonkeymike
23 Apr 2020, 14:49
Got green alps underneath. From a Zenith board where the badge was harvested and the cable was cut.
mcmaxmcmc
26 Apr 2020, 09:20
codemonkeymike wrote: 23 Apr 2020, 14:49 Got green alps underneath. From a Zenith board where the badge was harvested and the cable was cut.
Do you have the pictures of thr Zenith board by any chance? :)
xx776
28 Apr 2020, 19:44
Here`s my Acer 6311:
kelvinhall05
28 Apr 2020, 19:49
Nice, you should retrobright it :)
Khers
28 Apr 2020, 21:04
kekstee
29 Apr 2020, 23:25
My quarantine achievement is taking some new pictures of my current hhkb set up.
The HiPro uses silent sliders, others are stock. (imgur album)
sharktastica
01 May 2020, 12:14
Received my blue ANSI caps from Unicomp today, spicing up this On-The-Stick M13:
BadCommand
04 May 2020, 23:12
Hi all, first real post here. I've learned a lot from you all while lurking and thought it's about time I join the conversation.
kmnov2017 wrote: 16 Apr 2020, 18:59 And an F AT...modded to an F77 layout
Nice keycaps on your F AT! I need to have a nav cluster and num pad available, especially while teleworking during confinement. So it's interesting to see how people use their ATs. I've also spacebar modded mine, yielding an immediate increase in productivity 8-)
I added a nav layer under the right hand (very effective) but left the numpad in its original configuration. The other day my wife said, "it's moving the cursor instead of typing numbers!" So I pressed Num lock. "But now I can't use the arrows? WTF." :? So I'm testing out a sideways T nav. Let's see how it goes. Hey, at least it's not a block nav...
Unicomp keys
Unicomp keys
USB cable strain relief
Nuum
11 May 2020, 10:41
I recently built this custom G80-11800 with a YDKB Grape PCB, custom steel plate, Cherry MX Silent Blacks and EnjoyPBT 9009 keycaps. I also lined the case with EPDM foam to make it even more quiet and to have it feel more solid. It's still slightly pingy, though.
Custom G80-11800.png (1.85 MiB) Viewed 13472 times
I have 2 sets of plates for this layout left, they are not perfect and the arrows and numpad are on a separate plate, but they work fine. If anybody has a use for them, just PM me!
11 May 2020, 11:45
On the subject of sound: the creaky spring noise that MX silent switches make remains one of my least favourite things about the whole family. My Filco rings a bit, of course!, but even the slowest, gentlest keypresses creak, some switches more than others. The End key makes me picture a vampire lurching out a gothic door!
Nuum
11 May 2020, 12:11
On the Silent Blacks I don't notice any creaking until I go very close to the keyboard. Overall I'm really happy with the Silent Blacks, although the springs could be a tiny bit lighter for my taste.
On another custom board with Silent Reds it is much more noticeable and they are indeed quite inconsistent in creaking, but they obviously use a different, lighter spring.
11 May 2020, 12:16
Aye, my board o’ eerie silent creaks is indeed a Filco stocked with silent reds. Those coarse wound springs must be the culprit.
Are the different springs of reds and blacks (specifically the silent versions) actually the same gauge wire wound to a different coil count? Or is the wire itself distinct?
Nuum
12 May 2020, 18:48
This is probably not the right place to discuss this further, but we're on Offtopic-thority anyway! I took a quick comparison pic between a Cherry MX Silent Black (left) and Silent Red (right) spring. The wire is definitely different, but unfortunately I can't accurately measure the wire gauge with my crappy calipers.
MX Silent Black (left) vs Silent Red (right).jpg (48.01 KiB) Viewed 13339 times
I'd wager they're the same wire gauge and that the creaking stems from a tolerance issue with the spring rubbing against the housing somewhere.
AJM
12 May 2020, 20:14
The creaking comes from the spring rubbing against the peg in the bottom part, onto which the spring is stuck. A design flaw, that affects more or less every mx style switch. Thankfully it's easily solved with putting lube in this place.
12 May 2020, 20:54
The kind of “easily” which involves desoldering every switch in the entire Filco, I guess?
Some of us like switch modding. I do not belong to that group! What a hassle!
What’s extra annoying is I like the weight of reds, so no need to monkey around with custom springs (which I do have around here somewhere). And as these are silents, they are already damped. What really want from them is silky smoothness and mechanical silence, consistently across the keyboard. That’s a tall order for MX!
@Nuum
Sure looks the same gauge to me. Intriguing how much difference a coil count makes. Maybe there’s more to it than just that: a different alloy perhaps? The distinct colour raises that possibility. I mean, the only thing I really know about springs is Hooke’s Law. How does coiling them more reduce their return force? I’ve no idea.
Khers
14 May 2020, 20:01
DJSwayde
15 May 2020, 00:46
Khers wrote: 14 May 2020, 20:01 Image
What's the purple bit?
Polecat
15 May 2020, 05:27
Muirium wrote: 12 May 2020, 20:54 The kind of “easily” which involves desoldering every switch in the entire Filco, I guess?
@Nuum
Ahhh but it isn't coiling them more, it's the gauge and total length of the wire. A coil spring is just a torsion rod wound into a coil. When you compress it you're just twisting the wire. If you make it longer with the same gauge wire you'll have a lighter spring. Wound into a coil "longer" means more turns closer together.
Khers
15 May 2020, 09:02
DJSwayde wrote: 15 May 2020, 00:46
Kbdfnas' Polaris. Pretty good bang for the buck it has to be said.
16 May 2020, 12:26
Still for sale? I’ve plenty of caps and a fair few switches looking for a home. But I’m a picky snob!
Polecat wrote: 15 May 2020, 05:27
Ohhhh… more wire >> more spring. Gotcha!
Moitoy
18 May 2020, 19:11
Now im using my just finished first mechanical keyboard (Handwired 60%+numpad+1 extra row and ISO Spanish Layout) With khail box whites for alphas, box pale blue for modifiers and box orange for numpad and arrows
