IDENTIFY THE KEYBOARD thread
Noobmaen
13 Sep 2018, 15:51
Yes: Image
13 Sep 2018, 16:10
I'm also thinking Space Invaders. The board looks a lot like my 725.
risk23
13 Sep 2018, 19:06
Noobmaen wrote:
risk23 wrote: Another fleabay board. Any ideas? I could swear I saw something similar somewhere.. An ADDS terminal maybe?
Keytronic foam and foil, the old tall version.
I wish this forum had the bow-to-overlord emoji. Thank you, sir.
risk23
13 Sep 2018, 19:11
Another one I'm curious about, it's a Miniterm 1203s (late 70s) dumb terminal with dot matrix readout.
s-l1600 (4).jpg (153.87 KiB) Viewed 9709 times
s-l1600 (3).jpg (107.15 KiB) Viewed 9709 times
Noobmaen
13 Sep 2018, 19:15
Also tall keytronic foam and foil.
PlacaFromHell
13 Sep 2018, 21:17
Chyros wrote: I'm also thinking Space Invaders. The board looks a lot like my 725.
AWWWW YESS, white ciclops. Got it for 25 U$D plus 4 U$D shipping.
spongebob1981
14 Sep 2018, 16:57
Any chance you leave a vintage mech to me? :mrgreen: You keep sniping them!
You beat me to the beamer, this one, and another one I can't remember now...
Esp: Habría posibilidades de que me dejes alguno que siempre me ganas de mano? :mrgreen:
Ya te me adelantaste con el beamer, este y algún otro que no recuerdo.
Avisá cuando aparezca alguno que ya tengas así le puedo entrar yo =P
PlacaFromHell
14 Sep 2018, 19:46
Es pura suerte. Al final cancelé la compra del Unisys porque el vendedor nunca quería coordinar, así que si te interesa está publicado. :) Si tenés tiempo y ganas entrás a ML y buscás "teclado" sin más, filtrando por usados, cada tanto alguna joyita a buen precio aparece. La próxima me fijo si te consigo algo. :lol:
Keybug
14 Sep 2018, 22:00
Blaise170 wrote: Did space invaders have the same red circle LEDs like Keytronic had? That's usually what tips me off to F&F.
It would seem then that those LED windows in conjunction with yellow on the space bar only is a good indicator for space invaders? I assume Keytronic / foam and foil caps were rarley PBT so yellowing should be equally distributed on those boards?
BSKUA0
16 Sep 2018, 14:42
Identify please :roll: I can only say that judging by "typewriter" Russian layout sublegends, not more common DOS layout, it may be from ~1987 to ~1992.
Polecat
16 Sep 2018, 20:08
BSKUA0 wrote: Identify please :roll: I can only say that judging by "typewriter" Russian layout sublegends, not more common DOS layout, it may be from ~1987 to ~1992.
Taiwan buckling spring. I have one that's identical except it has no sublegends. No brand ID. Model TK-M501C. FCC IZITK-105M.
Interesting mechanism because you can change each switch from click to no click by removing and reinstalling the spring and lever the other way. There's a photo here someplace of the instruction sticker for that.
late edit: The keys won't register with the caps installed as "non clicky non tactile"! Bad assumption on my part.
BSKUA0
16 Sep 2018, 20:29
Polecat, thank you :)
Polecat
17 Sep 2018, 04:35
BSKUA0 wrote: Polecat, thank you :)
Found more info including the click/no click instructions under Syncam on the wiki:
wiki/Syncan_TK-M501C
spongebob1981
17 Sep 2018, 14:39
PlacaFromHell wrote: Es pura suerte. Al final cancelé la compra del Unisys porque el vendedor nunca quería coordinar, así que si te interesa está publicado. :) Si tenés tiempo y ganas entrás a ML y buscás "teclado" sin más, filtrando por usados, cada tanto alguna joyita a buen precio aparece. La próxima me fijo si te consigo algo. :lol:
Hoy empecé con albañiles en casa, así que el umbral de compra vuelve a subir hasta 'blue ALPS' hasta nuevo aviso =P
EDIT: Tengo algo con SMK linear vintage en casa, por ahí te sirve para tu otro proyecto. Esta noche veo de mandarte foto.
Keybug
17 Sep 2018, 20:46
Keybug
17 Sep 2018, 21:10
Any ideas on this beauty?
Black_Shadow99
18 Sep 2018, 03:01
Help please. I found while rummaging at some goodwill stores around me a Maxi Switch Inc. p/n 2189037-00-003 (there are 2 other parts numbers on it as well p/n 54191305 and p/n 9100862 which is attached to a barcode). It also says Network Computing Devices Inc on it (I did find out the it must be a keyboard for some kind of terminal because it has some some crazy keys on it like help, compose, and 2 diamond keys!). It also has a model number of N-123na but doing a search for that comes up with nothing. It has double shot keycaps and cherry mount stems but I dont know what kind of switches it has. Any help would be greatly appreciated. I'll get some pics uploaded in a few. Thanks.
Gamuholic
18 Sep 2018, 03:23
Black_Shadow99 wrote: Help please. I found while rummaging at some goodwill stores around me a Maxi Switch Inc. p/n 2189037-00-003 (there are 2 other parts numbers on it as well p/n 54191305 and p/n 9100862 which is attached to a barcode). It also says Network Computing Devices Inc on it (I did find out the it must be a keyboard for some kind of terminal because it has some some crazy keys on it like help, compose, and 2 diamond keys!). It also has a model number of N-123na but doing a search for that comes up with nothing. It has double shot keycaps and cherry mount stems but I dont know what kind of switches it has. Any help would be greatly appreciated. I'll get some pics uploaded in a few. Thanks.
Sounds like Maxi Switch dome with slider.
Blaise170
ALPS キーボード
18 Sep 2018, 03:56
Basically anything made after the 90s by Maxi switch is rubber dome of some kind. Maxi Switch actually made... Maxi switches before that but I've heard that they are nothing special.
Noobmaen
18 Sep 2018, 12:01
Keybug wrote: Any ideas on this beauty?
I think it is cortron foam and foil
Keybug
18 Sep 2018, 15:22
I see. Thanks!
Here's an undocumented Nixdorf board...
snufflecat
20 Sep 2018, 15:25
Any guesses which one this is?
Edit:
Plus this one? Big black one.
2018-09-20 15_29_23-Window.png (538.98 KiB) Viewed 9213 times
Blaise170
ALPS キーボード
20 Sep 2018, 16:23
The second one looks like it might be a rubber dome but I have no idea.
Polecat
20 Sep 2018, 17:24
The Acer would be a KB-084. Possibly blue Alps, but there were also Multitech foam and foil versions (See Chyros' recent Franklin FKB-3 review).
snufflecat wrote: Any guesses which one this is?
Edit:
Leshe
20 Sep 2018, 19:04
Any guess on this one?
PlacaFromHell
20 Sep 2018, 21:39
Leshe wrote: Any guess on this one?
Most Compaq keyboards are rubberdomes or foam and foil. Anyway, do you have more pictures?
Noobmaen
20 Sep 2018, 22:08
NMB dome with slider
Niko1U
21 Sep 2018, 13:13
I am confused, what is it?
TapX
21 Sep 2018, 13:37
Niko1U wrote: I am confused, what is it?
According to the wiki, wiki/IBM_6298389, it's a capacitive rubber dome keyboard, made in Japan. Seems quite interesting.
Niko1U
21 Sep 2018, 18:15
thanks! i googled it, but i didn't find anything. I agree, it looks interesting but the connector is weird
