Alps Appreciation
dss
01 Sep 2019, 00:33
//gainsborough wrote: 01 Sep 2019, 00:22 nice! I just got a NIB one off eBay as well - also whites. NIB whites though are still pretty nice! Does yours work well, BTW? I have to hot-swap mine in to actually be able to type on it. Generally, I'll start my PC with like an omnikey plugged in, then once it's booted up I'll unplug the omnikey and plug in the k104. It's very annoying.
Oh does yours also have the Northgate badge? I hadn't seen that anywhere before so I thought I'd post it here.
I only hooked it up once to test using a soarers converter but I didn't notice any issues.
//gainsborough
ALPSの日常
01 Sep 2019, 00:35
mine doesn't have the badge. I'm pretty jealous of yours! Hahaha. BTW nice to see a fellow Oregonian =) Blazer fan?
01 Sep 2019, 00:38
Very nice find! I love how even THIS one has a part number starting with 555 xD .
cli
01 Sep 2019, 01:26
dss wrote: 01 Sep 2019, 00:08 In fact I'm not sure I could tell the difference between these switches and the Blue Alps in my Northgate 102.
My Northgate 102 is in excellent condition but I suppose its not new like this one.
Think you get some yummy early whites..
wiki/Alps_SKCM_White
Curiously, it appears that the very first white Alps switches retained the dry lubricant and return spring material of blue Alps, indicating that the blue–white transition was not a clean break but itself a series of transitions; here, the older dry-lubricated version is held to be superior.
I have put the switches in a SGI Bigfoot ... it's sounds better than on my Monterey K102 board.
zrrion
01 Sep 2019, 01:27
What a coincidence but I also got a nib omnikey recently!
The only thing I'm not liking about it is the print screen key must be tapped twice. I've looked through the manual but I don't see any way to disable that, which is a shame as I would like to remap that key.
Polecat
01 Sep 2019, 01:41
dss wrote: 01 Sep 2019, 00:08 Check out this keyboard I picked up NIB from ebay recently...
A Monterey K104 with a Northgate (!!) badge.
It has SKCM White Alps and feels really excellent.
Nice! I saw that one listed, very glad it went to someone here. And thanks for the photos; the ones in the ebay listing were pretty bad. The early K104 is a really top notch keyboard.
The paper label matches the ones seen on Northgate models from other vendors, and this supports my previous guess that these labels were added by Northgate once the keyboards were delivered. And that also explains why the manufacturer's serial numbers don't correspond to the ones on the paper labels. I'm not sure what the "555" was about, but Northgate seemed to triple-up the digits on the vendor numbers, at least on the early models. Gen1 have a vendor number of 111, Gen2 was 222, 333, or 777. Some of the internal parts (PC board, etc) on Northgates seem to have numbers beginning with "555", so perhaps that was their designation for "keyboard" or the starting prefix on all their part numbers?
Like the Northgate-branded Liteon/Silitek 0002 I found this was probably supplied with a system rather than being sold separately like the Omnikeys. The "90" in the Monterey serial number is probably the year, 1990. The big (Datacomp) arrow keys means it probably has double shot caps. Your feelings about the early white Alps switches agree with mine; all else being equal I can't tell them from blues.
Polecat
01 Sep 2019, 01:47
Please share some photos. I just found a NIB K104 also, actually a K104W with windows keys, which I posted in the Gallery a few weeks back.
My old K104 never had any compatibility issues. I used it as native AT/PS/2 and also with a Radio Shack USB dongle and Soarers converter. Which position are you using on the slide switch? It should be in the center for AT. The two side positions are for XT, either normal or with caps lock latching (like a typerwiter).
Polecat
01 Sep 2019, 02:06
zrrion wrote: 01 Sep 2019, 01:27 Image
Northgate did the double-press on print screen on purpose, so you didn't accidentally do a screen shot if you bumped it. That was before the OS ignored that key unless you used the shift modifier. Unfortunately I don't know of a way to disable that.
zrrion
01 Sep 2019, 02:20
Well, that is a shame. I can always map the macros I was wanting to put on print screen/scroll lock/pause onto insert/home/page up and it will work just fine. Still, its weird that there isn't a dip switch to control that behavior (or a jumper or something)
Polecat
01 Sep 2019, 02:28
zrrion wrote: 01 Sep 2019, 02:20 Well, that is a shame. I can always map the macros I was wanting to put on print screen/scroll lock/pause onto insert/home/page up and it will work just fine. Still, its weird that there isn't a dip switch to control that behavior (or a jumper or something)
Don't know if this helps, but looking at the book they say, "All other functions accessed by this key are performed normally." So you don't have to press twice if you're using Alt-Print Screen or Shift-Print Screen.
cli
01 Sep 2019, 02:41
Ok, I got a turd
Keyboard is NOB, looks gorgeous, was hoping it had Alps switches. Ended up with some mehhh Alps clone switches (Xiang Min MX).
Only Alps is the touchpad.
zrrion
01 Sep 2019, 03:32
Polecat wrote: 01 Sep 2019, 02:28Don't know if this helps, but looking at the book they say, "All other functions accessed by this key are performed normally." So you don't have to press twice if you're using Alt-Print Screen or Shift-Print Screen.
I was planning to remap it to F13 and have Ctrl+F13 be a macro (I like macros on F13-F24 since nothing uses those by default) but It is not likely that Ctrl+print will conflict with anything so that might work. I'll have to test that out.
swampangel
01 Sep 2019, 15:11
zrrion wrote: 01 Sep 2019, 01:27 The only thing I'm not liking about it is the print screen key must be tapped twice. I've looked through the manual but I don't see any way to disable that, which is a shame as I would like to remap that key.
Wow, this had me baffled for a long time, I never even considered it was built into the keyboard and not something weird with my windows install
Polecat
01 Sep 2019, 17:26
swampangel wrote: 01 Sep 2019, 15:11
No, it was quite on purpose; they thought they were doing us a favor! I don't remember if the Gen1 (gold label) Northgates had that feature, but the Gen2 and Gen3 versions did. It's been too long for me to remember when it changed, but early versions of MSDOS did a screen dump to the printer with a single press of that key. Later versions used shift-print screen instead, for the same reason Northgate used a double press, to prevent accidental use. You wouldn't think it was such a big deal, but back in the day of daisy wheel and dot matrix printers a page dump could take several minutes.
01 Sep 2019, 18:34
Polecat wrote: 01 Sep 2019, 17:26
Off the top of my head, gold label ones don't.
Polecat
02 Sep 2019, 05:39
Chyros wrote: 01 Sep 2019, 18:34
Just confirmed that to be correct.
flowerlandfilms
02 Sep 2019, 07:28
Sometimes you get lucky.
Nabbed my self a drop in replacement for a One Per Desk Australian Telecom machine for $25 AUD.
In the mail as we speak.
http://blog.tynemouthsoftware.co.uk/201 ... epair.html
CountNoctua
02 Sep 2019, 21:43
flowerlandfilms wrote: 02 Sep 2019, 07:28 Sometimes you get lucky.
Gorgeous keycaps!
flowerlandfilms
03 Sep 2019, 19:25
CountNoctua wrote: 02 Sep 2019, 21:43
Gorgeous keycaps!
Yeh they are something special.
Nice thick Chocolate and Red doubleshots in Alps mount.
SpacemanToby
05 Sep 2019, 14:10
Alps mount? Dang those might be the coolest alps caps I've ever seen.
Mattr567
06 Sep 2019, 02:32
New build, still a WIP
flowerlandfilms
06 Sep 2019, 20:06
SpacemanToby wrote: 05 Sep 2019, 14:10 Alps mount? Dang those might be the coolest alps caps I've ever seen.
I also have a set of grey Alps sphericals in a similar style.
These ones just arrived and aren't as bright as the picture so will need a bit of retro brighting i think.
Rauha
11 Sep 2019, 21:04
Received today two sets of Krepublic's new blank PBT Alps keycaps.
They are the fullest option sets with both ISO and ANSI support and plenty of '3U space bar and split shift' type of options for small children and mentally ill adults.
Not a huge fan of XDA profile, but still nice to have options for Alps. Especially like the ISO support.
Thickness is decent.
Being the idot that I am, I did not even think about stabilisers when making the order. It turns out that they have Cherry mounts for (all) stabilisers.
Also got two Taihao greens in the same order. They are indeed as insane as the 280g weighting implies.
ppCircle
11 Sep 2019, 22:27
Unitron keyboard with Alps Green switches
PCB has cherry mount
(more photos later)
maxpower56
11 Sep 2019, 23:12
Anyone got a source for NOS SKCL Yellow? The old taobao links seem to be out of stock.
flowerlandfilms
25 Sep 2019, 12:14
Ok, so I got my Atessa finally from Yahoo Auctions, I was poor at the time so I had to choose Seamail, and it's taken months.
Another transparent Alps board for the collection, but there is some weirdness here.
I have no experience with black Alps, my At-101 had white, but these feel wrong for what they are supposed to be. First of all, they are clicky, half way down there is a sharp tactile bump and a loud click, and secondly, they bind like a motherf$_&er on off key presses.
Off centre on the bottom of a given key is fine, but off centre on top is like fighting a dog for a bone.
Are Black Alps genuinely this shit? Or are these some kind of clone that has printed the Alps logo for legitimacy?
After I clean and retro bright it I will post more pics.
EDIT:
Took one apart...
It's simplified, hence the crappiness.
Guchay
17 Oct 2019, 08:47
Acer KB123 with SKCM Blue Alps! I replaced the original macro keys at the top with blanks for now because some of the keycaps were missing. Also appears to be missing a power button/joystick on the upper corner, although I can't verify what used to belong there. Also has quite a funky layout, with a 10 unit spacebar without blockers, ansi enter but split backspace, side f keys, and a cross nav. The sound of this board is unreal, sounds way better than all of my blue alps boards I currently own hands down. Hopefully I can get it converted and restored. :)
cli
17 Oct 2019, 19:09
flowerlandfilms wrote: 25 Sep 2019, 12:14
Took one apart...
Yes, simplified Fukka switches
wiki/Alps_SKBL/SKBM_series
I had a Matias board with these switches. Kind of meh switches, I desoldered all the Fukka switches and replaced it with Alps dampened switches.
The click leafs are not bad, I replaced the click leafs from a Dell AT101W board with it. Not as good as Alps White Pine, better than click modded Alps Black Bamboo.
Polecat
18 Oct 2019, 04:26
Guchay wrote: 17 Oct 2019, 08:47 Acer KB123 with SKCM Blue Alps! I replaced the original macro keys at the top with blanks for now because some of the keycaps were missing. Also appears to be missing a power button/joystick on the upper corner, although I can't verify what used to belong there. Also has quite a funky layout, with a 10 unit spacebar without blockers, ansi enter but split backspace, side f keys, and a cross nav. The sound of this board is unreal, sounds way better than all of my blue alps boards I currently own hands down. Hopefully I can get it converted and restored. :)
Nice find, thanks for sharing! Interesting shade of blue if the photo is accurate.
Guchay
18 Oct 2019, 05:23
Polecat wrote: 18 Oct 2019, 04:26
