IDENTIFY THE KEYBOARD thread
eatleadin321
28 Apr 2020, 20:34
Does anybody know what switches this keyboard uses?
https://www.ebay.ca/itm/ACK-700-POS-Ter ... Swp6Reob8t
Their website says it is rubber dome, but why does it have removable caps and sliders then?
kelvinhall05
28 Apr 2020, 20:45
Are you after the Victor that the link goes to, or the original item?
The Victor has Peerless.
eatleadin321
28 Apr 2020, 20:46
The ACK-700, which should be the original item.
ddrfraser1
28 Apr 2020, 21:58
shine wrote: 28 Apr 2020, 17:51
ddrfraser1 wrote: 28 Apr 2020, 17:11 Weird. Looks like decent build quality and good layout. How is the feel? Similar to while alps or Montereys?
To the touch is clicky but softer than Alps, similar to SMK blues, but the sound it makes is very close to skcm white/blues, really really good. I will probably make a video comparing the sound of both switches.
Impressive considering it seems to be a knock off. Looking forward to the comparison vid. Compare to matias and monterey too if you have any :D
eatleadin321
28 Apr 2020, 22:30
Could the ACK-700 be a slider over dome switch? the slider doesn't look similar to anything i've ever seen.
kelvinhall05
29 Apr 2020, 16:00
https://www.ebay.ca/itm/Vintage-DataDes ... 4708505428
SMK inverse cross, right? Any good? Are SMK sensitive to dust (like, is a NOS one the best you can get)?
Considering picking this one up...
Polecat
29 Apr 2020, 17:21
kelvinhall05 wrote: 29 Apr 2020, 16:00 https://www.ebay.ca/itm/Vintage-DataDes ... 4708505428
Be aware that's a special version of the Datadesk, as evidenced by the label and the odd 8 pin DIN connector. My guess (and it's only that) would be that it's for a Tandy 2000.
edit: that should probably read Tandy 1000 instead.
mhinsch
06 May 2020, 23:50
I bought these keycaps about a year ago on ebay. Does anybody by any chance know which keyboard they originally belonged to? It's obviously Micro Switch, but that's as far as I got.
kelvinhall05
07 May 2020, 01:27
xx776
08 May 2020, 16:35
Is this Cherry G80-3000 Mechanical ?
kelvinhall05
08 May 2020, 16:56
xx776 wrote: 08 May 2020, 16:35 Is this Cherry G80-3000 Mechanical ?
Pretty sure all G80 3000 had either MX or MY, so yes, it is mechanical.
MMcM
08 May 2020, 18:00
mhinsch wrote: 06 May 2020, 23:50 I bought these keycaps about a year ago on ebay. Does anybody by any chance know which keyboard they originally belonged to? It's obviously Micro Switch, but that's as far as I got.
The System 10 had CTL for the F keys. https://archive.org/details/bitsavers_s ... 2/mode/1up
The DRS20 had the same shifted number legends and colorway. https://collection.sciencemuseumgroup.o ... splay-unit
So perhaps something in that Singer / ICL lineage, like a System 25?
kps
08 May 2020, 20:04
MMcM wrote: 08 May 2020, 18:00 The DRS20 had the same shifted number legends and colorway. https://collection.sciencemuseumgroup.o ... splay-unit
Suspect it's a keycap variation of the same keyboard. Here is a close-up of another version and a clearly matching LOCK light spot.
mhinsch
08 May 2020, 22:34
kps wrote: 08 May 2020, 20:04
Yes that looks indeed very similar. Thanks!
Edit: And the second one is actually from Bracknell, which is where I currently live. That's a weird coincidence...
mcmaxmcmc
09 May 2020, 02:07
Yes, it should have Cherry MX switches, I'd guess black. They aren't super vintage though, being made in 1999.
Lekrafter
09 May 2020, 08:36
This keyvoard is for an IBM 4683 POS system, what I'm wondering is, is it anything special, or just a rubberdone?
P
John Doe
09 May 2020, 08:39
I like it, even case its membrane.
davkol
09 May 2020, 11:23
derp
ddrfraser1
13 May 2020, 14:56
Anyone know what switches this thing uses and if it can talk to a pc? Couldn’t find on the wiki.
kelvinhall05
13 May 2020, 15:01
iirc decision data has rubber domes.
Omegasupreme33
13 May 2020, 23:52
Hello everyone, just looking for some info if anyone has it for this board bought a while ago. I know who makes it, just can't find anything on it. I can take more pics if anyone needs them but this was made by Access Keyboards.
John Doe
14 May 2020, 06:13
Got these two fujitsu boards these days, top one is clicky and bottom is linear. Totally no idea whats this, anyone could help? Thanks.
14 May 2020, 07:40
Omegasupreme33 wrote: 13 May 2020, 23:52 Hello everyone, just looking for some info if anyone has it for this board bought a while ago. I know who makes it, just can't find anything on it. I can take more pics if anyone needs them but this was made by Access Keyboards.
Welcome on DT.
As you know the manufacturer, perhaps you should simply ask them whether they still have any info and/or material:
https://www.access-is.com/
And please do contact me if you ever consider getting rid of it - or at least of the "Trouble" keycap :mrgreen:
shine
14 May 2020, 09:52
John Doe wrote: 14 May 2020, 06:13 Got these two fujitsu boards these days, top one is clicky and bottom is linear. Totally no idea whats this, anyone could help? Thanks.
you should open them, look at the model number written in the pcb and update the wiki. Switches on the top one are Fujitsu Leaf spring 2nd generation and bottom are 3rd gen.
14 May 2020, 13:27
Fujitsu leaf spring
Omegasupreme33
14 May 2020, 16:31
kbdfr wrote: 14 May 2020, 07:40
Welcome on DT.
If I get Access to give me ANY information on this and the Trouble key is yours. Never figured to ask them directly because it's not a retail board. I'll keep you updated!
Robauke
14 May 2020, 20:15
Hello folks,
this keyboard is the reason I registered, i just wanna know more about it, its merits and how to do it justice.
I recently got into thrifting for old hardware and build myself a windows 98 PC, so i can tinker a bit with old hardware and games. Ofc the PC is turning into a exibit piece, and thats where this keyboard comes in.
Its not just any keyboard but a suprising find in my parents house. Its a tool of my late father, who was some sort of earned journalist in Würzburg, Germany. I recall him as always stressed, this keyboard still reaks of his overboarding smoking habits. It works fine, I cant find any flaws. I assume he just put it aside at some point, deemed it outdated.
Its not at all from the age that i am familiar with, the one that has windows key. I understand its an AT keyboard with nice mechanical cherry switches. The keys are easy to remove and clean (which i did with the numpad) i dont really plan to open the case for further cleaning. AEG is a well respected company but not for computer hardware, so the label is an eyecatcher. Im lucky there is still the 5Pin adapter attached.
So is this the quality keyboard it seems to be, or more an average product of its time? What was its time?
Can its worth be put into numbers?
The yellow keys are itching me to dip my feet into retrobright adventures, do you guys think thats a terrible idea?
The case and the greyer keys seem to have no signs of yellowing.
There is some black stains close to the AEG logo i would like to rub off, i did so on other parts of the case. Is the aeg print prone to damage?
Lekrafter
15 May 2020, 03:10
Good evening everyone!
Would anyone be so kind as to enlighten me on what keyboards these are and what switches they might have? Thank you
kelvinhall05
15 May 2020, 03:20
Zenith has rubber domes, no idea on the other one.
15 May 2020, 11:32
Robauke wrote: 14 May 2020, 20:15 IMG_20200514_193701.jpg
Hello folks,
  1. Your keyboard is obviously a straightforward Cherry G80-1000 with an AEG Olympia branding, the real giveaway being the Cherry-label size of the recess on the back.
  2. I don’t think i is worth very much, but there are certainly people who would buy it just in order to desolder the swithches, as vintage black switches are some sort of (in my eyes undeserved) hype. It would be a pity to destroy such a nice collector’s item.
  3. I wouldn't attempt retrobrighting without having first acquired some retrobrighting experience with completely worthless stuff.
    Alternatively, you can simply replace the badly yellowed caps with less yellowed ones, which are quite easy to find.
  4. To eliminate the black stains near the logo, you can use a Q-tip moistened with (not soaked in) ispropanol* - gently rub without touching the logo and wipe dry with a kitchen tissue
    *not the 70% solution sold under the Hetterich brand in German pharmacies (which by the way is a perfect disinfectant against Covid-19), but pure stuff, which your pharmacy will sell you for a few Euros, perhaps asking first what you need it for because of other possible usages
