Alps SKCCAF002A
24 Feb 2015, 00:24
My goodie box arrived today:
Alps SKCCAF -- box 1.jpg (470.21 KiB) Viewed 8200 times
Already opened, admittedly.
Closer …
Alps SKCCAF -- box 2.jpg (447.61 KiB) Viewed 8200 times
Closer …
Alps SKCCAF -- box 3.jpg (655.28 KiB) Viewed 8200 times
Lotsa switches!
Alps SKCCAF -- lotsa.jpg (495.7 KiB) Viewed 8200 times
The original packet was "officially" labelled, which gives us "proof" of SKCC series and SKCCAF:
Alps SKCCAF -- NOS.jpg (620.13 KiB) Viewed 8200 times
Sadly no original Alps datasheets, packaging etc. Who did take the other three thousand, nine hundred and fifty, anyway?
I'm going to keep one left permanently disassembled, as they're a pain to disassemble and the side tabs are more than willing to fly off and hit you in the face:
Alps SKCCAF -- fragile side tabs.jpg (45.35 KiB) Viewed 8200 times
I never did find where it went.
And lo, what's this …
Alps SKCCAF -- opened, 1.jpg (72.72 KiB) Viewed 8200 times
Not what I was expecting:
Alps SKCCAF -- opened, 2.jpg (101.98 KiB) Viewed 8200 times
Grey switchplate! This must be a later issue. There's also a ridge along the bottom of the base to hold the switchplate that seems to be a modification to the design.
24 Feb 2015, 00:45
Alps... just when you think you discovered all of a branch, it opens up new branches of evolution.
24 Feb 2015, 00:51
They chose the right name for themselves.
24 Feb 2015, 01:22
I seem to have the same switch as that used in the M0110A:
Reference: http://kbtalking.cool3c.com/article/29717 (alps.tw)
This figures, as the M0110A came after the introduction of SKCL.
24 Feb 2015, 09:33
really good pictures!
cherry-jade
24 Feb 2015, 15:17
I got about ten keyboards with this kind of switchs.
24 Feb 2015, 15:18
cherry-jade wrote: I got about ten keyboards with this kind of switchs.
let´s see a pic cherry-jade! 8-)
24 Feb 2015, 23:58
All tall cream Alps?
Per the wiki—[wiki]Alps SKCC Tall Cream[/wiki]—this switch is only known to have been used in the Apple M0110 and M0110A: do you have other keyboards with this switch?
Or are you referring to SKCC in general?
This is the oddest one:
From: http://www7.ocn.ne.jp/~hisao/image/x.htm (MouseFan)
The keyboard itself remains unidentified and sadly there isn't a photo of the PCB or controller IC to give us some idea of branding or manufacturing date.
SKCC itself had a clear overlap with SKCL; here's a 1985 one with the green switches:
http://www7.ocn.ne.jp/~hisao/image/paso700.htm (Also MouseFan, and with the PCB code this time)
25 Feb 2015, 00:15
That LED looks very tactile.
25 Feb 2015, 00:22
Great find!
:ugeek:
let me know if you want a keyboard designed for them.
25 Feb 2015, 00:24
I only have 50 and there's at least one person who wants to get his hands on them already.
You're not suggesting that you have spare keycaps for them, are you?
25 Feb 2015, 00:29
No, not at all.
25 Feb 2015, 00:30
Round 6.
25 Feb 2015, 00:37
One day, someone will make a keyboard that's exactly the same as my Poker II, but 75% …
cherry-jade
26 Feb 2015, 16:15
I made a mistake. This is my KEYB.
26 Feb 2015, 17:45
Nice cherry-jade. Those look like green (and cream) Alps vintage tee mount. What keyboard are we looking at?
26 Feb 2015, 20:13
cherry-jade wrote: I made a mistake. This is my KEYB.
It's a good visual indication that green is lighter than cream, as cream is used for all the heavier and stabilised switches. The switches appear to all be the normal height.
What does the PCB ID say? It's clearly 12KC-something, maybe 12KC081O, but it's too small to read. I presume there's no code anywhere on the keyboard that begins "KFCC" or "KCC"?
cherry-jade
27 Feb 2015, 11:56
The keyboard named pasopia 700. TOSHIBA
27 Feb 2015, 12:01
cherry-jade wrote: The keyboard named pasopia 700. TOSHIBA
Cool. More pictures please!
27 Feb 2015, 21:57
seebart wrote: Cool. More pictures please!
He's already destroyed the ones he posted earlier, which are now 404. The keyboard is simply the one I posted earlier:
However, MouseFan's example seems to have a different PCB code (12KC284A) but I no longer have the other images for comparison, also undermining the ability to use this topic as a visual reference point for green being lighter than cream. (MouseFan's page doesn't prove or disprove the use of cream switches, so he might have a different revision of the design with uniform switch weight.)
28 Feb 2015, 08:47
Oh well I guess cherry-jade does not feel like sharing then.
cherry-jade
28 Feb 2015, 13:22
seebart wrote: Oh well I guess cherry-jade does not feel like sharing then.
I'm sorry. It's late to report you,7BIT has post the adress of that keyb. Mine is exactly the same as his.
cherry-jade
28 Feb 2015, 13:25
28 Feb 2015, 13:35
OK thanks for the link! 7bit owns the same keyboard? I did not know that.
cherry-jade
28 Feb 2015, 14:03
Not destroyed. The station which i set my picture is wrong.
28 Feb 2015, 14:25
There is a slight communication problem here but that's OK cherry-jade.
28 Feb 2015, 14:36
They're still hotlinked attachments from another forum — that's way too fragile for my liking.
28 Feb 2015, 14:49
Good thing I'm not in charge here![emoji45]
28 Feb 2015, 16:28
You can banish me if you want.
28 Feb 2015, 17:04
Daniel Beardsmore wrote:You can banish me if you want.
Most definitely not! Apart from that I am just another user here with no admin role whatsoever as you well know. Anyway what I was trying to communicate is that cherry-jade is sharing little info's possibly due to a language barrier. But I do not know that for sure.
