Name Those Rings
02 Mar 2015, 20:53
These rubbery rings came along with a miscellany of caps I got lately.
Anyone know what they are? About the same size as small coins, and several millimetres thick. I have more than this, perhaps a whole keyboard's worth, if that's indeed where they go!
Could they have something to do with IBM Selectrics / beamsprings? Because there were indeed some of those caps in the box. And the slots are similar in the rings to those in beamspring caps.
Among others.
And a bunch of Clare Pendar switches and caps I already posted.
Mysterious!
Nuum
02 Mar 2015, 21:09
Maybe key blockers for beamspring switches? I.e. they go onto the stem so that you can't depress the switch?
chzel
02 Mar 2015, 21:17
Or maybe dampers? Something like o-rings for Cherry MX?
02 Mar 2015, 21:22
Plausible. Trouble is I don't have the keyboard they came from, they're just spare parts.
If they're IBM, then whatever keyboard it was, it wore those blue and grey caps. Who's stripped down a Selectric, I wonder? (PMing Cindy…)
elecplus
02 Mar 2015, 21:36
They ring a bell, something ancient in the attic. I will go look in a little while. Are they flexible, easily bent, or pretty firm?
Of all the 40+ beam springs that have come through here, I have not seen these on any of those.
Redmaus
Gotta start somewhere
02 Mar 2015, 21:37
Beam Spring O rings!
Not that you would want to silence such a click/clack...
elecplus
02 Mar 2015, 21:40
The RM1 reminds me of an old calculator that had several memories. You could figure multiple equations or columns of numbers, and store the results from each in a different memory location.
02 Mar 2015, 21:42
Thanks Cindy. They are likely old indeed, probably early 80s. Flexible, quite supple. They do strike me as chunky, vintage o-rings! But it's just a guess.
HaaTa
Master Kiibohd Hunter
06 Mar 2015, 08:13
You know what's scary, I think I recognize nearly all of those keycaps...
06 Mar 2015, 09:14
HaaTa wrote:You know what's scary, I think I recognize nearly all of those keycaps...
That's not scary, that's impressive!
06 Mar 2015, 12:06
Nearly? Do elaborate!
HaaTa
06 Mar 2015, 18:38
ImageDSC_0525 by triplehaata, on Flickr
Not quite, but pretty close (https://plus.google.com/photos/11384566 ... 5823397356)
Closer?
ImageUntitled by triplehaata, on Flickr
The RM1, R and 0,3,4 keys are almost certainly from calculators.
Almost, but not quite (https://plus.google.com/photos/11384566 ... 5823397356)
Pretty good methinks
ImageDSC_1099 by triplehaata, on Flickr
The only one I'm pretty sure I haven't seen is the Print/Send Line keycaps. But it looks like there's some sort of insert...
06 Mar 2015, 18:41
Muirium wrote:Nearly? Do elaborate!
There you go Mu! ;p
06 Mar 2015, 19:50
Ah, well those unseen caps are the ones I actually have an ID for! They're the internal lightbulb Clare switch caps I had in the other thread:
I've three of them, I think. The white one is in the foreground here. Translucent, ready for the wee bulb that slides in as it's pressed down around it, which would make it brighter when pushed:
I like all three of these caps. The others are unrelated, but they have a central window right in the stem for their own indicators. Again smarter than what we have around today.
Anyway, I need to shoot a bunch more pictures (I promised Facet I would) and do a real stock take. Ah winter's everdark, you're almost over now…
