Not to long ago I bought a mechanical keyboard and some time ago some extra keycaps. They arrived today and all buttons but one went on easy.
The caps lock. If I put on the default keycap it works normal, when I put on the new one it makes a wierd sound and goes off very easy - it just does not fit very well.
On the old keycap the "cross" looks way bigger, maybe that is the problem?
Second question. The bigger keys have wired "connections". How do I know if I put them on correctly again?
Thanks
