ITT Courier with Micro Switch SC.Monster-Toys wrote: 01 Jun 2019, 22:30 Any Idea what switches are in this one (and further info about it)?
IDENTIFY THE KEYBOARD thread
- Gamuholic
- Main keyboard: GMMK with Kailh BOX White
- Main mouse: Logitech something or other
- Favorite switch: Beam spring
- DT Pro Member: 0252
- Monster-Toys
- Main keyboard: IBM Model F PC AT QWERTZ
- Favorite switch: IBM Beam Spring
Thx. Interesting board... I am tempted to buy it, price is kinda steep tho (170€).
- Monster-Toys
Hmm... rubber dome... i will pass then, 170 is too much to gamble and the seller refuses to give more info or more photos without keycap (maybe he knows why ^^), thx (still like the look of the board tho)Chyros wrote: 02 Jun 2019, 01:20 As I recall that's a board with Micro Switch rubber dome (ST) switches. Could be wrong though.
- Gamuholic
You're right, I meant ST, not SCChyros wrote: 02 Jun 2019, 01:20 As I recall that's a board with Micro Switch rubber dome (ST) switches. Could be wrong though.
- Chyros
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
I thought it might be SMK inverse cross mount because it has a similar bottom row profile, but couldn't find an exact match. What makes you so sure it's not BTC?
- PlacaFromHell
- Main keyboard: IBM 3101
- Favorite switch: Beamspring
Well, the blue Alt keycaps and the ramp style wrist rest, also the single unit Esc key. Unfortunately I think it was sold.Keybug wrote: 02 Jun 2019, 20:33 I thought it might be SMK inverse cross mount because it has a similar bottom row profile, but couldn't find an exact match. What makes you so sure it's not BTC?
- Keybug
I don't think the large Esc key is a given for all BTCs (see here). The steep reverse slope keycaps remind me of Olivetti, except for the bottom row. Come on, someone solve this mystery...
This video? https://youtu.be/WknsauSpVUk (Keyboard crasher's lunch)consideringquiet wrote: 27 May 2019, 04:55 Saw this in a "viral" video stop motion of a man eating his previous keyboard.
Anybody got an idea as to what this board may be?
Both keyboards are well identified.
The membrane keyboard he cuts is Perixx PERIBOARD-106 (the label is clearly visible):
https://www.amazon.com/Perixx-PERIBOARD ... B01BFCBNEI
The RGB mechanical keyboard in the end is Ajazz AK510, it even sells on Massdrop.
https://drop.com/buy/ajazz-ak510-retro- ... l-keyboard
He also writes that he used "Filco's white-axis mechanical switch keyboard and truly's blue-axis mechanical switch keyboard." for the sound. Not really sure but it probably means Filco with Cherry MX Clear (are there any stock Filco's with clears?) and Truly Ergonomic Keyboard (?) with Cherry MX Blue (they really sell those, dreadful noise aside MX Blues are pretty tactile).
- Main keyboard: HasuAlps 60% Build with SKCM Orange Alps
- Main mouse: Lenovo N50
- Favorite switch: Orange Alps, Zealios 67g
can someone tell me if these have alps switches or not? I know there are a handful of hewlett packard boards that have cream alps, but I don't remember if compaq ever made any alps boards, i feel like i might have seen one somewhere, but i might just be misremembering an HP board.
- zrrion
- Main keyboard: F122
That is foam and foil iirc
- DT Pro Member: 0011
Yep. Key Tronic foam and foil.
A historic computer nonetheless: the first fully compatible clone of the IBM PC and what gave Compaq its name.
Findecanor wrote: 07 Jun 2019, 20:06 Yep. Key Tronic foam and foil.
thank you kindly good gentleman. i knew it was just wishful thinking on my part, just needed the experts to confirm to bring me out of denial. it was the hewlett packard luggable with cream alps i was thinking of. whew. bullet = dodged, and the quest continues...Chyros wrote: 07 Jun 2019, 20:39 I have one of those. The computer doesn't work and the board is shit xD .
- Keybug
Got myself this great condition Chicony 5160. The caps seem ALPS mount to me (hasn't been sent yet). I'd never seen one with a phone-style connector before...
- 2_5160.jpg (186.34 KiB) Viewed 11530 times
- 1_5160.jpg (208.38 KiB) Viewed 11530 times
- Monster-Toys
I would guess it is a Oemmax MCK-860 (high chance of blue alps afaik)
- TheInverseKey
- Main mouse: M570
- DT Pro Member: 0216
I have an OEMMAX MCK-860 and this does look like one as well but I have never seen it with the RJ10 connector.
EDIT: Also looks like there is a din connector that comes out of the case which is interesting.
- Keybug
On second thoughts, the 86... serial number seems to indicate it's an MCK-860 after all. Still, rather stupefyingly similar.
Yummy blue ALPS then. Oh goodie!
- Chyros
Chicony did use Alps/Silitek-style cases like that (also others though), but the caps are very different from early-era Chicony ones, and the lock light sticker (one of the biggest differentiators for 5160-style keyboards) is uniquely different.
- Main keyboard: Lately an Ortek 142 though I swap out boards
- Main mouse: logitech
- DT Pro Member: 0239
Hey! I think I got that board off ebay the other day
The switchs though....mmmmmm...mmmmm
- Polecat
I recently bought a NOS KB-5160 (Futaba) to use the PC board and plate in a Franklin case. I can make you a deal on the Chicony case if that helps.keyboard Kultist wrote: 11 Jun 2019, 22:26
Hey! I think I got that board off ebay the other daySerial number and little smudge close to the broken clip are the same. The seller (or someone) wrapped the top case in some sort of cammo.....doesn't look awful, but that's why I was thinking of transplanting the innrards into a model F case. Sadly that came to nothing.
Mine has the same lock light overlay as the Alps version, and also the big rectangular front feet, both different than the OEMMAX.
I'm definitely interested! How much were you thinking?Polecat wrote: 12 Jun 2019, 05:22I recently bought a NOS KB-5160 (Futaba) to use the PC board and plate in a Franklin case. I can make you a deal on the Chicony case if that helps.keyboard Kultist wrote: 11 Jun 2019, 22:26
I'm relatively new here on deskthority, how do we do this?
- Keybug
- Polecat
PM sent.keyboard Kultist wrote: 12 Jun 2019, 19:44
- ppCircle
- Main keyboard: Focus Fk-2002 HS Alps Blue / IBM 5140 Alps Brown
- Main mouse: Rival 300
- Favorite switch: Alps Blue / Alps Amber / Alps Brown / Alps N Green
Any ideas what switches can it have?
