IDENTIFY THE KEYBOARD thread
- Lalaland124
- Main keyboard: 3278
- Favorite switch: Beamspring
Is this the IBM Model M122 or F122 ?
- Screenshot_20210214-152239.jpg (832.65 KiB) Viewed 6726 times
- Screenshot_20210214-152226.jpg (1018.74 KiB) Viewed 6726 times
- Main keyboard: F AT / Pingmaster
- Main mouse: something cheap
- Favorite switch: I'll need to try more first!
Nixdorf keyboard with ominous switches. Does anyone have an idea what these are?
- $_57 (5).jpg (199.35 KiB) Viewed 6680 times
- $_57 (4).jpg (145.71 KiB) Viewed 6680 times
- $_57 (3).jpg (227.57 KiB) Viewed 6680 times
- Go-Kart
- Main keyboard: HHKB & AnyKey
- Main mouse: Orochi v2
- Favorite switch: Topre 45 g & MaxiSwitch D/S
O.K. guys, Lion Tech. Read a bit about one model being made by Dih Shin bit I can find little else. More interested in this style of dome with slider; haven't seen one like it before. Anyone recognise it?
Adam
Adam
- s-l1600.jpg (354.55 KiB) Viewed 6610 times
- s-l1600 (2).jpg (174.53 KiB) Viewed 6610 times
- s-l1600 (1).jpg (253.13 KiB) Viewed 6610 times
- Dome Slider Mystery.jpg (235.52 KiB) Viewed 6610 times
- rjohn
- Main keyboard: WASD VP3
- Main mouse: finalmouse UL2
- Favorite switch: cherry black
thanks for your comments,cause some members were interesting about this keyboard i am posting some more photos :
https://i.ibb.co/kghTZpV/1.jpg
https://i.ibb.co/Dw6dSSB/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/4Rg5XRf/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/Rzt0C2y/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/VVPRH2M/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/sJG4v03/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/7tPH0wj/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/31wD9Gb/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/Zd7JMjD/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/tHTffMy/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/JqccD2Z/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/mq0CXMG/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/rpR632k/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/FntWPk4/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/fQDXrDw/OLYMPUS-DIGITAL-CAMERA.jpg
https://i.ibb.co/RD0MZN8/OLYMPUS-DIGITAL-CAMERA.jpg
keyboard was connected here :
- Main keyboard: N/A
- Main mouse: N/A
- Favorite switch: N/A
https://www.liveauctioneers.com/item/98 ... ter-pieces Is this a Beamspring? (I call dibs on one if anyones interested in the other 3)
- JP!
- DT Pro Member: 0194
Not a Beamspring. This is Xerox, not IBM.Tonyv_73 wrote: ↑15 Feb 2021, 18:17https://www.liveauctioneers.com/item/98 ... ter-pieces Is this a Beamspring? (I call dibs on one if anyones interested in the other 3)
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
wiki/Fujitsu_Siemens_KBPC_S2Rhododendron wrote: ↑14 Feb 2021, 19:17Nixdorf keyboard with ominous switches. Does anyone have an idea what these are?
Rubber dome.
- Lalaland124
Found this online for 6euros, is this an Alps switch?
- Screenshot_20210218-125632.jpg (1.49 MiB) Viewed 6336 times
- DT Pro Member: 0011
Please use the IDENTIFY THE KEYSWITCH thread when you know the keyboard but not the switch.
BTW. The Switch recognition guide is also a good resource, although I can't identify this one there.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
- Lalaland124
Thx, will post it in the right forum the next time - my apologies
- leetuser
- Main keyboard: Custom Hackjob
- Main mouse: MX Master
- Favorite switch: ALPS
I have a buckling spring board here. I looked up the FCC ID it seems to belong to Can Technologies. There's even an entry in the wiki about the FCC ID but this keyboard is different. No model or manufacturer listed but it lists the same patent numbers. It's clearly newer as it has windows keys.
- IMG_20210222_005904.jpg (141.61 KiB) Viewed 6115 times
- IMG_20210222_010035.jpg (285.75 KiB) Viewed 6119 times
- IMG_20210222_010027.jpg (262.11 KiB) Viewed 6119 times
Branded "Syncan" or "Can". The model number is there in the FCC ID after the grantee code. https://www.youtube.com/watch?v=un65h8NWSAE
- Main keyboard: Kinesis Advantage2, JIS ThinkPad,…
- Main mouse: I like (some) trackballs, e.g., L-Trac
- Favorite switch: #vintage ghost Cherry MX Black (+ thick POM caps)
There's this ad: ACS (Alpha Computer Systeme)-branded Key Tronic E03623ELGRKTC-C (105key German layout, DIN5 connector) with "Key Tronic MPR II-KEY" on the spacebar.
It's quite clear what keyboard it is (another CIGE03600W), I'm just curious what the "Key Tronic MPR II-KEY" on the spacebar means. I found this older thread where the box reads:
Is it the grounding?MPR II
Exclusive conductive spacebar for enhanced environmental safety
- Willy4876
- Main keyboard: Focus FK-2001 with Alps Doubleshots
- Main mouse: Logitek MX Master 2S
- Favorite switch: Blue Alps
Yeah that's what I thought too but I didn't see mention of an ANSI version on the wiki. The legend placement on the numpad 0 is pretty distinctive though. Especially when combined with the bold arrows. If I manage to get it then I'll try to post an update.
- AJM
- Main keyboard: Vortex ViBE (with Silent Inks)
- Main mouse: steelseries Sensei RAW
- Favorite switch: Silent Ink
- DT Pro Member: 0231
Does anybody know, what kind of switches that Seequa Chameleon keyboard uses:
https://www.ebay.co.uk/itm/RARE-Vintage ... Swmyle5qqe
- Main keyboard: Kinesis Model 130
- Main mouse: Logitech M-S48, Razer Viper
- Favorite switch: MX Browns
Keytronic foam and foil I think. The position of the lock lights are either that or space invaders, but the keycaps look like doubleshot DCS so it can't be space invaders.AJM wrote: ↑02 Mar 2021, 22:11Does anybody know, what kind of switches that Seequa Chameleon keyboard uses:
Of course with a replacement PCB, keycaps and switches, it's be a great case (powdercoated bent metal).
- Main keyboard: Model M SSK
- Main mouse: Corsair M65
Rayndalf wrote: ↑03 Mar 2021, 00:00Keytronic foam and foil I think. The position of the lock lights are either that or space invaders, but the keycaps look like doubleshot DCS so it can't be space invaders.AJM wrote: ↑02 Mar 2021, 22:11Does anybody know, what kind of switches that Seequa Chameleon keyboard uses:
Can confirm, f&f
- TNT
- DT Pro Member: 0250
Are you guys sure? The caps look very similar to the ones on my Unitek K-150L. That would mean they could be some form of Cherry switch...
- TNT
Alright, nevermind. They look an awful lot like the caps of those Compaq XT boards. So most probably f&f.
- s-l1600.jpg (178.81 KiB) Viewed 5676 times
- Polecat
Just checked my database, and there is a K101 listed with ANSI Enter, no filler keys on the bottom row, and "K102 style case". Switches are blue SKCM. Rebranded as "Staff". No promises, but this could be a nice find.
I have an ANSI "Staff-K101" with model number Staff K9AX, and SKCL greens. K101 style case, but with blockers instead of filler keys on the bottom row. Not the same, but thought it was similar enough to mention.
- received_834382913718134~3.jpeg (1020.81 KiB) Viewed 5629 times
- received_550391502225304~2.jpeg (186.91 KiB) Viewed 5629 times
- AJM
Thank you very much.Rayndalf wrote: ↑03 Mar 2021, 00:00Keytronic foam and foil I think. The position of the lock lights are either that or space invaders, but the keycaps look like doubleshot DCS so it can't be space invaders.AJM wrote: ↑02 Mar 2021, 22:11Does anybody know, what kind of switches that Seequa Chameleon keyboard uses:
(I would have been more interested in the keycaps and PCB (if they would have been MX compatible), though. I find the shape of the case a bit .... "rudimentary".
Thanks to Lecrafter and TNT as well.
80's industrial makes me feel something.AJM wrote: ↑03 Mar 2021, 09:19Thank you very much.Rayndalf wrote: ↑03 Mar 2021, 00:00Keytronic foam and foil I think. The position of the lock lights are either that or space invaders, but the keycaps look like doubleshot DCS so it can't be space invaders.AJM wrote: ↑02 Mar 2021, 22:11Does anybody know, what kind of switches that Seequa Chameleon keyboard uses:
Oh if the caps weren't F&F I'd be all over it... well not really, I don't want to orphan a complete luggable if I can avoid it.
- AJM
Me too. There is actually another seller with only the keyboard, but - cunning as I am - I chose to post this offer as a reference to avoid pointing to many eyes to "my" link. Just in case it would have turned out as desirable as I hoped.
