It's foam and foil... sorry to disappointEricDauphinais wrote: ↑28 Mar 2021, 22:57Ordered one simply because I was too curious, now will need to figure out how to convert it...
IDENTIFY THE KEYBOARD thread
- Main keyboard: Model M SSK
- Main mouse: Corsair M65
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
Ah, sorry about that! Though I was bidding partly through curiosity - I hadn't asked him for a switch picture. At least we both get to see now! Typing feel is not as good as Alps, but it's an intriguing board and switch. I'll open it up and see if it matches the internals of 4_404's.
- Palatino
Thanks for that - yes that's a perfect switch match except the colour. Are your white ones clicky too? I'll open up the keyboard and see if the internals are the same too.4_404 wrote: ↑29 Mar 2021, 01:28I have a Fullmark board with what looks like a white version of the same switch. I thought I identified the switch, but have subsequently forgotten what it was. My Fullmark board is identical to two other boards I have with ISNJK-168/268 FCC ID (Limtech) (one with SKCM white, one with AO2 clones), apart from the label and PCB - the same as wiki/Brain_KB-9001S, but without the RB88. Note the 368 number on the plate. Sorry for the garbage photos.Spoiler:
Yeah mine are clicky, and pretty decent switches. The click leaf is visible in the opened up switch photo. They were pretty dusty when I got them, but cleaned up very well.
- Go-Kart
- Main keyboard: HHKB & AnyKey
- Main mouse: Orochi v2
- Favorite switch: Topre 45 g & MaxiSwitch D/S
That's pretty good going. I found Type 0A2 switches to be such a hassle to reassemble that I desolder them all and then cleaned them...
- PlacaFromHell
- Main keyboard: IBM 3101
- Favorite switch: Beamspring
What in the world is this thing?
- Thorogrimm
- Main keyboard: Niz C103
- Main mouse: Razer Viper Mini
- Favorite switch: Topre Electro-Capacitive
What's the ID on it?
- PlacaFromHell
I really don't know, is the only picture.
- Thorogrimm
After a trawl through the deskthority wiki I've found maybe two contenders for similarities.I really don't know, is the only picture.
Hi-Tek 15039-003
or
Sejin Electron EAT-1010
But neither of those are identical. Maybe someone with photographic memory and a vast library of a brain could indentify this keyboard. Looks generic seeing as there's no badge. And without any FCC ID it's pretty difficult to even tell what switches this thing even has. Where did you get the image?
- PlacaFromHell
Thanks for your help, but I can tell right away that this thing isn't made with NMB switches by the keycaps. Maybe it just has some type of Alps clones.Thorogrimm wrote: ↑31 Mar 2021, 15:57After a trawl through the deskthority wiki I've found maybe two contenders for similarities.I really don't know, is the only picture.
Hi-Tek 15039-003
or
- PlacaFromHell
Leaving aside the first mistery, I have an even bigger one. This thing is driving me ABSOLUTELY MAD, hours of search and still nothing about it:
The LED positioning is the only big clue of what's inside, being Fujitsu, Key Tronic and Microswitch equally possible. I decided to produce this forensic portrait of how I think the entire keyboard looks like:
- Main keyboard: M0115 with sculpted canon caps
- Main mouse: razer naga
- Favorite switch: brown alps
can anyone ID this board?
3h left in the auction if someone wants to make the sacrifice in the name of science.
https://buyee.jp/item/yahoo/auction/h290279466
those are alps cut outs for the LED's are they not. it looks somewhat similar to the epson business full keyboard. but definitely not topre underneath there, right? model reads pckb8. or do alps only have centered led cut outs. man i really wanna see what kinda switch it has.
- onigiritaroujp-img1200x900-1510212284ms5uro18408.jpg (44.03 KiB) Viewed 5604 times
It does indeed look a bit like Epson's Topre:
wiki/Epson_Business_Full_Keyboard
Besides the spacebar, the caps scream PBT. Wouldn't surprise me if it was a Topre.
- Thorogrimm
The cap profile does look a lot similarMuirium wrote: ↑02 Apr 2021, 11:55It does indeed look a bit like Epson's Topre:
- derzemel
- Main keyboard: FC660C, SSK, TX-1800 Nixie
- Favorite switch: Alps SKCL/SKCM tactile
I also have a strange one to identify, a Philips with, what it seems to be, relegendable keycaps. Sadly I do not have more details:
- Philips
- 4_n.png (571.42 KiB) Viewed 5475 times
- kps
- Main keyboard: Kinesis contoured
- Main mouse: Kensington Slimblade trackball
That's an interesting combination of legends. It has some ASCII-bit-paired caps (e.g. ‘;’/‘+’ and ‘:’/‘*’) but also non-ASCII characters (‘¬’) and a Hollerith card combo (10-8-2, which had various interpretations, typically ‘±’ or ‘\’ or ‘⏨’).
Shifted-6 would have been useful information (e.g. ‘&’ or ‘^’ or ‘↑’ or ‘¢’) as well as the other obscured key. And, well, focus.
This is something I can actually speak on due to my foray with using sony pve-500's to get OG BKE Domes.Muirium wrote: ↑02 Apr 2021, 11:55It does indeed look a bit like Epson's Topre:
You see these controllers could also come with a type of omron switch. The omron and topre has the same keycaps profile afaict. How did you tell them apart? The omrons have square LED windows in the top left, and the Topre have round ones in the top right
This won't be topre, could be omron though. my guess is fujitsu leaf spring or peerless
- derzemel
Thank you for the details! I have asked for better images.kps wrote: ↑11 Apr 2021, 19:57That's an interesting combination of legends. It has some ASCII-bit-paired caps (e.g. ‘;’/‘+’ and ‘:’/‘*’) but also non-ASCII characters (‘¬’) and a Hollerith card combo (10-8-2, which had various interpretations, typically ‘±’ or ‘\’ or ‘⏨’).
Thank you for the url.
I also found 2 older topics (first, second) about another Philips with similar switches.
Also this awesome album of images taken by @HaaTa of a Loewe TBT02 keyboard (from a Loewe BTX Decoder DBT 01 - videotext system?) that seems to have the same keycap design and similar switches.
- Main keyboard: KBD 8X MkII
- Main mouse: Logitech G903
- Favorite switch: Tealio V2
Could not find any info on this board. I am intrigued since it has a big a*s enter like a terminal keyboard from the olden days and split backspace. All I can give to identify is the LCP logo on top right, it connects with PS/2, is made in China and it sports a "SK-900-1" marking on the model label, apart from common FCC jibberish.
The case also isn't super thin and seems big enough to house mechanical switches.
- Main keyboard: BTC 5169
- Main mouse: CZC GM600
My guess would be a Silitek rubber dome.
- Main keyboard: HasuAlps 60% Build with SKCM Orange Alps
- Main mouse: Lenovo N50
- Favorite switch: Orange Alps, Zealios 67g
can anyone identify what kind of keycaps these are? or confirm my suspicions? my guess is laser etched?
and also, are these alps SKBM white switches? they look kinda yellow.
keyboard is SMK-8851
- i-img980x735-1604850725lsrnxn2317812.jpg (191.37 KiB) Viewed 5086 times
- i-img735x551-1604850726skjvde981888.jpg (121.01 KiB) Viewed 5086 times
- i-img980x735-1604850723yuons9982830.jpg (193.74 KiB) Viewed 5086 times
- zrrion
- Main keyboard: F122
those are pad printed caps, switches are a 4 tab clone of some sort. I did have a version of that board at one point with SKBM grey but I guess yours is a later version since it has clones. chassis is nice IMO
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
Looks to me like 4 tab Alps clone.the_ambyguous wrote: ↑23 Apr 2021, 23:35can anyone identify what kind of keycaps these are? or confirm my suspicions? my guess is laser etched?
wiki/Hua-Jie_AK_seriesthe_ambyguous wrote: ↑23 Apr 2021, 23:35
- Main keyboard: AEK II
- Main mouse: Apple Magic Trackpad 2
Front has Bull logo on it, backside says Zenith.
Does that make sense? And if it’s Zenith, anyone has an idea about the switches?
Thank you all!
Thank you all!
- Zenith IB-0050 label on the back of a Bull keyboard
- DC8230B9-C262-422B-823C-43A1E9C2CD57.jpeg (123.78 KiB) Viewed 4980 times
- Front of Bull keyboard - supposedly made by Zenith
- 44B0C114-159D-4FA1-BDF5-51F3576482AC.jpeg (497.43 KiB) Viewed 4980 times
- Main mouse: MX Master 3
Dome
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Made in Japan; what do we reckon? Something Fujitsu underneath (LED in top left of switch)? Plug is round, but I guess it won't be standard DIN...
- IMAGE_1619342831867_1339084210812400781.jpg (134.31 KiB) Viewed 4905 times
- IMAGE_1619342831781_4341528960900137095.jpg (159.85 KiB) Viewed 4905 times
- Lalaland124
- Main keyboard: 3278
Fujitsu Lead Spring 2nd Gen?
- Screenshot_20210425-132219.jpg (966.38 KiB) Viewed 4891 times
- Screenshot_20210425-132217.jpg (1001.85 KiB) Viewed 4891 times
- Screenshot_20210425-132213.jpg (983.96 KiB) Viewed 4891 times
Maxiswitch 2186004XX keyboard - any idea what kind of switches?
- 35BE4A10-86FC-4A19-B3A4-AFDED1516966.jpeg (470.28 KiB) Viewed 4887 times
- 6C39D610-95BF-43CC-855B-71FC0BCE0F8A.jpeg (470.14 KiB) Viewed 4887 times
