Tunning an M spacebar for an IBM F
idollar
i$
11 Apr 2015, 12:48
Hello,
one of my 107s have a damaged spacebar.
I wanted to use an M bar, but as you may know, the size of the stabilizer is thicker in the M than the one in the F
If used, the F stabilizer will be loose in the M bar:
I read a post in which washer were used to hold the M stabilizer.
My solution has been a different one.
I fill the hole completely with epoxy. When it was solid, I drilled a hole of the size of the F stabilizer. The result works very nicely.
I should have cleaned the excess of glue with a cutter blade. But to be honest, I did not notice the excess until I zoom into the pictures.
Hopefully this is useful for some others.
Cheers
i$
11 Apr 2015, 15:27
Quite a novel idea.
Since F spacebars and wires are rare and M bars and wires are common, most mods adapt the F barrel frames to accommodate M gear, hence the home-made tabs and washers. I usually add M-sized tabs to my F mods in hopes that it will make them more future-proof.
idollar
i$
11 Apr 2015, 15:33
fohat wrote: Quite a novel idea.
The beauty of this solution is that it does not modify anything that is not available today. So it is always possible to go back,
A pre-requisite is to have the wire.
Mal-2
11 Apr 2015, 20:11
idollar wrote: The beauty of this solution is that it does not modify anything that is not available today. So it is always possible to go back,
You can fabricate a wire from an appropriately sized paper clip, a couple pairs of pliers, and patience, and once again, nothing (but a paper clip) is lost if you fail.
idollar
i$
11 Apr 2015, 20:16
That's also a good idea. The video that I saw in youtube seems to be more complicated.
https://www.youtube.com/watch?v=dA8IpiIgwxo
12 Apr 2015, 00:31
Of course, the amazing wcass created the most elegant solution of all, when he used tiny metal tubes as sleeves to enlarge the ends of the F wires to fill the M holes.
I have looked hard but I can't find it, a couple of years old, probably.
Touch_It
13 Apr 2015, 17:41
fohat wrote:Of course, the amazing wcass created the most elegant solution of all, when he used tiny metal tubes as sleeves to enlarge the ends of the F wires to fill the M holes.
Very elegant. However I am not. I borrowed the idea from someone, can't quite remember this morning, but I used heat shrink tubing on my model f wire. Works quite well. Small break in period as I didn't use a small enough wire but cheap and easy.
14 Apr 2015, 03:39
That was from me. 1/4" piece of heat shrink on the ends of the F wire to allow it to fit in the M spacebar.
Mal-2
14 Apr 2015, 04:07
Touch_It wrote: Very elegant. However I am not. I borrowed the idea from someone, can't quite remember this morning, but I used heat shrink tubing on my model f wire. Works quite well. Small break in period as I didn't use a small enough wire but cheap and easy.
If the difference is that minimal, might a couple layers of nail polish do the trick as well?
Touch_It
14 Apr 2015, 04:09
I don't see why not. I think it would take a fair amount of coats and I couldn't comment on durability.
15 Apr 2015, 03:25
Model M on top, Model F in the middle / bottom. They aren't that different. Just different enough that the M wire is too thick to fit under the F retainers on the barrel plate and the F wire is too thin to mount in the tabs on the M spacebar.
