319 key keyboard?
elecplus
11 May 2015, 17:33
http://www.pixel77.com/kickstarter-spec ... -keyboard/
Now there is a keyboard that ought to be able to handle just about any shortcuts!
chzel
11 May 2015, 17:54
Unfortunately it seems that there are only 20 programmable keys, the rest are application specific shortcuts.
Better get 3 Tirpo 128-key matrices and customize it to perfection!
Ask kbdfr! He'd know!
11 May 2015, 18:23
nice but its got nothing on the hyper7
http://deskthority.net/w/images/4/45/HONEY_HYPER7.png
chzel
11 May 2015, 19:07
Got pic???
:evilgeek:
:shock:
Soon?
elecplus
11 May 2015, 19:22
Pic is towards the bottom of the page.
chzel
11 May 2015, 19:24
I meant it for Andrew, who so boldly suggested a layout designed by 7bit, which will be produced........just in time for our grand-children to use!
elecplus
11 May 2015, 20:11
My oldest grandchild is 7, so maybe by the time he finishes high school?
11 May 2015, 20:13
That's a tight deadline in 7bit space.
Touch_It
11 May 2015, 20:56
My Tipro board with MX blacks
It feels embarrassed.
elecplus
11 May 2015, 21:26
I like it!
Mal-2
12 May 2015, 01:30
chzel wrote: Unfortunately it seems that there are only 20 programmable keys, the rest are application specific shortcuts.
There are other answers to this problem, such as my daily driver:
Or the one I'm selling in this thread:
You can program every key on it, but I will admit that if you try to do really funky things like I am on the matrix keyboard, you may encounter ghosting issues because the matrix is optimized for the alpha area being at lower left, not upper right.
If you really want up to 144 programmable/macro keys, get the G86-63400 and use it just for that, retaining your normal keyboard for typing. You will have to replace the two 2U keys at lower right with four 1U keys to do this, but what do you know, I'm selling some of those too.
elecplus
12 May 2015, 01:34
I have over 30 of the bottom one, but they do not give enough extra keys :-(
Mal-2
12 May 2015, 01:36
elecplus wrote: I have over 30 of the bottom one, but they do not give enough extra keys :-(
Every key on it can be used as an "extra key". You'd just have to do your actual typing on a second keyboard if you did that.
elecplus
12 May 2015, 01:40
You are giving me ideas, and my husband will tell you that is not a good thing to do! Probably best if I tackle this after I get my parents moved, in another month or so :-)
12 May 2015, 02:48
... and what if any of those shortcuts changes in the next version of PS? Then the Shortcut-S will be obsolete.
Still ridiculous. Instead of (or in addition to) the user learning the shortcuts on a regular keyboard, she would have to learn what
each icon means - that is not always straightforward.
