Funsaver!
Redmaus
Gotta start somewhere
31 May 2015, 08:44
I recently acquired a IBM "Space Unsaver" keyboard. I have been searching for this particular board for over a month.
All I could find was the one Ellipse was selling for 550$. :| I actually did consider paying this, but I slept over it and decided that there had to be another way. I knew I could find my dream keyboard for a feasible price.
I was right. In this thread:
http://deskthority.net/photos-f62/ibm-3 ... 10494.html
I learned that a user named dorkvader(who is also global moderator over at GH) had two. I PM'd him afterward and after discussing it in depth, why I want it etc he offered a very reasonable price of 150$ shipped. He included the original cable, xwhatsit controller, let me have the nicer case and unmodded unsaver, and superb packaging on top of all that.
I would also like to point out he helped me a lot when I was converting my wyse to USB with a pro micro on which I am typing on now.
Now on to the pictures! :P
When It Arrived
Sorry I didn't get better photos of the outer box and great packaging. A family member had mistaken the parcel for their own by the time I got home that day. I had 1000% excitement at this point
What Came In The Box.jpg (366.92 KiB) Viewed 8135 times
Everything that came. The cable is quite oddball. Before I took this picture I had clicked the keys a bunch :mrgreen:
Overview
At this time I had my F122 close and I could definitely tell that the unsaver felt much better compared to the F122.
This could be because of multiple reasons:
-The keyboard could be used less, and the springs have less wear.
-Due to its smaller frame, the metal tabs compress the board better and it has a better tactile feel.
-I messed something up while doing my ANSI mod( I hope not) or the art foam I used doesn't work that well.
The day I got it I knew I was going to take better pictures of it the next day and I wanted to be able to move the keyboard around easily without damaging/breaking the internal components or breaking off the plastic outside of the piezo clicker or DIP switches.
This is one of the CAD unsavers. The difference is the rainbow plate and the odd connectors and DIP switches and a clicker comes with the CAD ones. The other unsavers have a 5-pin DIN cable that can be converted easily. I would need the other unsaver model in my possesion or some better pictures other than what I can currently find to list some more specific differences.
I am critical on preserving all original parts of the board and to store the stuff I probably won't ever use such as the D-sub connectors or insulation paper and have the parts that I could use in the future like the piezo clicker stored to where they won't get lost/damaged in the meantime.
Next part, the better photos I took :)
Unsaver Keyboard Pictures
True Love.jpg (263.36 KiB) Viewed 8135 times
I love the symmetry of this board. Dreamy Layout. Some of the keys have some odd front printed legends on them. I don't think these are pad printed. They look dyesub to me but I can't be sure. One of these keys should interest Muiruim.
Open Assembly.jpg (230.71 KiB) Viewed 8135 times
The case has three screws that hold it together. The assembly is secured to the board with metal clips instead of screws. I added in screws after I properly stored all the original components. The barrel plate has some corrosion and rust, but nothing I can't handle and certainly not as bad as quantalume's. The foam appears to be in good condition.
Rainbow Plate.jpg (218.81 KiB) Viewed 8135 times
The plate is beautiful. The vibrant colors are a vivid rainbow that shines like gold. Makes the back plate for my F122 so drab and boring.
Rainbow Plate Back.jpg (228.16 KiB) Viewed 8135 times
There are two tags on the back. The feet are still rubbery and are the same ones on my F122.
Rainbow Sticker.jpg (296.02 KiB) Viewed 8135 times
Also the 21 on the date means the 21st week of 1984 I believe.
Bare Assembly.jpg (229.98 KiB) Viewed 8135 times
Not much to see here. Moving along.
Bare Assembly Back.jpg (226.03 KiB) Viewed 8135 times
The back of the board had tape along the tabs that I removed and stored properly. There is also a rather large controller and another sticker.
Back Sticker.jpg (245.14 KiB) Viewed 8135 times
Don't really know what to make of these numbers.
This thing is definitely the largest model F controller I have ever seen. Or on any keyboard for that matter. It connects to the DIP switches, clicker and both D-sub connectors. Look how small the xwhatsit is compared to it.
Unsaver Keycaps
Bold Dyesub.jpg (167.35 KiB) Viewed 8135 times
All of the keys are one piece and have a thick grainy texture that I like and the dyesub legends are very thick, you can tell that IBM used more ink for these keys.
Compared to a regular two piece model M cap. I think the legends are bolder on the unsaver but less sharp and refined. The texture in my opinion is better than the M cap however. The unsaver cap is the one on the left.
Thats all for this post, stay tuned for the next one featuring all the pieces inside the keyboard and how they were stored.
Redmaus
31 May 2015, 08:44
Unsaver Components and Storage
These are all the screws used in the board excluding the ones that secure the ports to the backplate. They all have a certain heft that seems bulkier than the screws on some of my other model M's. The gold screws are for the controller, the blue anodized ones are for the outer case.
Here is the clicker for the unsaver. This component is exclusive to the CAD ones. At first I thought it was a solenoid, but turns out I was wrong. I am curious however if this clicker is any different than the ones on 4704 keyboards. Could someone in the comments post a detailed picture of the clicker for his/her F107 or kish? After hearing the difference between both the clicker and the solenoid, I like the solenoid much more and I see how the clicker could get annoying very fast. dorkvader mentioned he has one around somewhere that I could probably have. The little knob on the front is volume control, I believe.
Speaker Back.jpg (259.94 KiB) Viewed 7973 times
Two wires soldered to the back and on the connector, but I notice the pins on the xwhatsit controller have six. How do I connect this clicker to the xwhatsit properly?
Large D-sub.jpg (220.44 KiB) Viewed 7973 times
Here is the main connector that plugs into the original cable. I think the keyboard output goes through here.
Small D-sub.jpg (209.57 KiB) Viewed 7973 times
I heard in a few places that this is the input or something. I don't know what this was used for, but I would love to be enlightened if anyone else does.
DIP Switches.jpg (254.27 KiB) Viewed 7973 times
I actually quite like the look of these DIP switches. The red on the switches look very sharp when on the back plate. If can, I want to use these after I convert the board to USB. I would definitely rather use the switches than just have an empty hole in the back plate. :D
Clip and Screw Baggie.jpg (272.85 KiB) Viewed 7973 times
I have the original clips and port screws in this little baggie. I decided to use screws instead of the clips so I could open the board easier and I think screws will hold it together a little better.
Open Box.jpg (210.57 KiB) Viewed 7973 times
As you can see, this has all components in the keyboard excluding the controller, tags, and tape.
Closed Box.jpg (185.83 KiB) Viewed 7973 times
All sealed up and ready to be put in drawer ;)
Tags and Tape.jpg (207.65 KiB) Viewed 7973 times
I didn't want to just shove the tags still on the port connectors in the box too because they felt brittle and delicate. So I put them in baggies with a paper slip to indicate which component they belonged too so I could keep track. The clicker did not have a tag I do not know if this is the case for all CAD unsavers. There were three pieces of tape that sealed the metal tabs on the back. You can see some of the sticky residue on the back of the assembly in the previous pictures.
Stay tuned for more pictures and info regarding what will happen with the funsaver. :)
Redmaus
31 May 2015, 08:45
FEEL THE RAINBOW!!!
HEYAYAYAY
HEYAYAYAY
Feel The Rainbow.jpg (176.07 KiB) Viewed 7841 times
Redmaus
31 May 2015, 08:45
Place holder 3
zts
31 May 2015, 09:08
:shock: super awesome shit stuff. Love it :!:
Khers
31 May 2015, 09:11
Congratulations on acquiring a very beautiful board, and at a non-Elliptical price as well! The unsaver is up there with the kish at the top of my list of boards I would love to own. Quite jealous, if I'm honest! :D
31 May 2015, 11:28
Congrats Redmaus! Your collection is getting impressive. Nice pictures.
chzel
31 May 2015, 11:33
Congrats, it's a fine board!
Glad you decided not to go elliptical on this!
idollar
i$
31 May 2015, 12:12
Congratulations.
We will be waiting for your pictures.
photekq
Cherry Picker
31 May 2015, 13:19
Ugh.. Very jealous :cry:
Redmaus wrote: I have been searching for this particular board for over a month.
Pfft.. That's nothing! Try 16 months..
31 May 2015, 14:13
How true, this is one those keyboards I don't think I will find. Ever. Now if I was living in the states the chances would be higher.
eldorange
31 May 2015, 15:16
photekq wrote: Ugh.. Very jealous :cry:
Try finding one here!
hammelgammler
Vintage
31 May 2015, 15:25
Wow such a beauty, and all of that for that price...
I would say i'm searching for an Unsaver even longer, and it seems like that won't change very quick. :(
Absolutely my dream keyboard, nearly perfect layout, superb look and Model F switches.
I would say i want an F50 keypad more then a Kishsaver. :D
vivalarevolución
formerly prdlm2009
31 May 2015, 15:29
Dorkvader with the hookup. Nice.
Redmaus
31 May 2015, 18:15
What exactly are you searching for? I might be able to help :D
photekq
Cherry Picker
31 May 2015, 18:18
Redmaus wrote: What exactly are you searching for? I might be able to help :D
NIB Original Cherry ANSI dyesubs w/ red cyrillic legends.. :x
The $750 offer from my classifieds thread is still standing..
31 May 2015, 18:25
1x Kishaver. 1x Beamspring. 1x Unsaver. That's all. I'm a modest man. 8-)
I'm placing this order with you Redmaus! :evilgeek:
Redmaus
31 May 2015, 18:30
Sorry if I get only one unsaver somewhere it goes to Ace first. But I find more than one consider yourself lucky! ;)
But before I can even attempt to look for people I need to sell all of my other boards first. I don't even need huge profit gain just enough to make back the time I spent grabbing the boards. We can work with prices everybody I am very flexible. I made a GH thread on it and not a single reply. So I need some buyers if you guys want me to find rare kb's.
photekq
Cherry Picker
31 May 2015, 18:31
Beamspring is yours seebart if you find those dyesubs for me.. :lol:
31 May 2015, 18:34
photekq wrote: Beamspring is yours seebart if you find those dyesubs for me.. :lol:
yeah you had to throw that in... :x Damn it. All this leverage.
I'm gonna quote this from today just for the hell of it...
Today's µTranslation: Der Schatz im Elektromüll = The shitstorm in the electronics mall?
photekq
Cherry Picker
31 May 2015, 18:37
Did I mention that the internals are immaculate? The foam is like new! I will even throw in a free controller once I get one :mrgreen:
Now get searching.. :maverick:
dorkvader
31 May 2015, 21:25
I was looking for the right buyer for over 2 years.
hammelgammler
Vintage
31 May 2015, 22:11
If that was your problem i would have been glad to take that Unsaver... :D
But maybe Redmaus was the better choice, as i don't really had the chance to test Model F buckling springs, but from what i can read it has to be better then Model M buckling springs. :)
macmakkara
31 May 2015, 23:10
Grats! nice board there. My was in pretty much worser shape than this and its missing 3-5 caps. Don't remember cause im using other board caps.
Redmaus
31 May 2015, 23:30
macmakkara wrote: Grats! nice board there. My was in pretty much worser shape than this and its missing 3-5 caps. Don't remember cause im using other board caps.
Now you can't torture me anymore with your unsaver! :mrgreen:
hammelgammler wrote: If that was your problem i would have been glad to take that Unsaver... :D
Don't think that is fair, having you as a choice would be as good as me. But I think I wanted the unsaver more though. :D
Yeah model F is 3x better than M springs.
Volks
02 Jun 2015, 07:12
1x ANSI Olivetti doubleshot 1x ANSI Olivetti dyesub. :( That's all I am looking for.
snoopy
02 Jun 2015, 09:03
1x APL Unsaver for me please.
ramnes
ПБТ НАВСЕГДА
02 Jun 2015, 09:11
1x Kishy pl0x
02 Jun 2015, 10:41
+1 1x kishy please !
chzel
02 Jun 2015, 11:08
1 Kishy for me as well! Where do I pay?
