swill's plate builder
Eszett
27 Jun 2015, 13:10
Hi! I have a question regarding swill's plate builder tool. For an ergo layout I rotated the keycaps in keyboard-layout-editor, but swill's plate builder tool did not correctly process this data, the rotation is shifted awkwardly, see screenshot. Is this a bug? What can I do?
plate distorted.jpg (29.16 KiB) Viewed 2459 times
salsaverde
28 Jun 2015, 06:55
Maybe try opening the CAD file in an editor and see if it can be corrected manually.
Eszett
28 Jun 2015, 20:11
Didn't help. I've downloaded the SVG file from builder.swillkb.com, converted the SVG file to *.KiCAD_PCB format, and opened it in KiCAD. There, I mainly see black void. See screenshot. The original layout in keyboard-layout-editor.com is stable, here is the link to the original layout: http://www.keyboard-layout-editor.com/# ... 769c9f72d1
Charger
28 Jun 2015, 22:43
I don't think swills tool works with rotation from keyboard-layout-editor
Eszett
28 Jun 2015, 23:41
@Charger Thanks for affirmation. I need to rotate manually in an appropriate CAD application then. I checked out QCAD for this purpose, but am not quite satisfied with it's useability ...
