- IMGP0071.JPG (998.59 KiB) Viewed 4573 times
- This one dates 40th week 1978.
- IMGP0106.JPG (974.86 KiB) Viewed 4573 times
- The metal leafs that hold the switch housings are exactly the same as those on my MICRO SWITCH SW-10591. The metal construction on which all this is fixed on the PCB and the hall sensors also look the same.
- IMGP0076.JPG (986.68 KiB) Viewed 4573 times
- PCB
- IMGP0074.JPG (1000.22 KiB) Viewed 4573 times
- The linear switches, the springs and housings and the are exactly the same as those on my MICRO SWITCH SW-10591.
- IMGP0101.JPG (675.74 KiB) Viewed 4573 times
- Now for me the best part of the whole thing are the keycaps. Easily the nicest I own.
- IMGP0125.JPG (995.66 KiB) Viewed 4573 times
- The layout is beyond me. The colors are great. I should really have a metal case made for this. Notice there are quite a few blanks also. A num cluster in the alpha section like on the SSK. Those caps show heavier wear than the rest.
- IMGP0142.JPG (973.15 KiB) Viewed 4573 times
- IMGP0127.JPG (925.08 KiB) Viewed 4573 times
- IMGP0129.JPG (1016.32 KiB) Viewed 4573 times
- Shot with flash.
- IMGP0151.JPG (978.93 KiB) Viewed 4573 times
- Shot with flash.
- IMGP0153.JPG (1014.65 KiB) Viewed 4573 times
