model f help?
MECHGAMER
- Main keyboard: cooler master tk mx green
- Main mouse: razer naga 2011 molten
- Favorite switch: ibm buckling spring capacitive
I just got my new F122, and four keys in the numpad don't click, I'm suspecting a bent plate, but I'm not sure. will post photos tomorrow.
- Redmaus
- Gotta start somewhere
Try reseating the key. If that does not work, most likely a bent spring.
Will need pics to know for sure.
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
The springs and flippers are what goes wrong on buckling spring, not the plates.
By far the most common fix for a non-clicky key is to take off the cap a few times and try to tilt the spring right when you re-attach the cap.
If the spring has a kink in it, then you'll need to replace it using the "chopstick" method.
MECHGAMER
- Redmaus
You sure that's an F?
Looks like an M.
Looks like an M.
- idollar
- i$
- Main keyboard: IBM F or M
- Favorite switch: BS
This picture looks like from a model M as Redmaus said : http://i.imgur.com/egpHvFx.jpg
Are the barrels mounted in a metal plate ? In case of a positive answer it is a model F. If not, it is an M
Another indication is the back of the case. If metal F. If plastic M.
cinnamonrollz
- Main keyboard: Model F Unsaver
- Main mouse: A turd logitech wireless mouse
- Favorite switch: Buckling Spring/Blue Alps/Beam spring
thats not a model f, If you bought it as one id ask for my money back. metalic ping is suppost to be there.
- Redmaus
MECHGAMER
actually, the m sound more like a thock, and the f has a lighter sound, my keyboard sounds like the F AT in this sound comparison: https://www.youtube.com/watch?v=Mbt1EjDcCHU
serial: 1389162, 08 december 1987
MECHGAMER
I paid $30 for it, so its still a good deal even if its an M. I'll post more pics of it, including the insides and the back when I get home.
MECHGAMER
I actually believed it was an F because the seller said so(stupid mistake). Still a very good board.
back label:part no: 1389162
ID no.:1035127
date: 08DEC87
Plt no:F5
Model M
IBM corp 1985
Next time I should probably ask the seller for more pics of the item before buying.
I don't have access to a camera as of now, and how do you open one of these?
ID no.:1035127
date: 08DEC87
Plt no:F5
Model M
IBM corp 1985
terrycherry
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
Maybe you should find more info about the keyboard and switch when you buy it. Most seller don't know their keyboard very much.
- dorkvader
- Main keyboard: Unicomp
- Main mouse: CST 1550
I've got a few of the F122 and only 1 m122, you just get a thinwall nutdriver.MECHGAMER wrote: I actually believed it was an F because the seller said so(stupid mistake). Still a very good board.
ID no.:1035127
date: 08DEC87
Plt no:F5
Model M
IBM corp 1985
7/32" or 5.5mm is standard for normal model M. My M122 isn't the usual kind but it has the same.
$30 isn't bad for a M122. If you get tired of it, you can always chop it down to "unsaver" size.
