- Alps Compatible
- Uses Apple Extended Keyboard II keycaps (dye sub PBT) and stabilizers
- 0.090” alumium for the top and bottom plates on the case (switch plate is recessed to allow the switches and stabilizer inserts to properly snap into place)
- 0.375” CNC milled Lexan for the center spacer
- 60%+left-hand numberpad layout to allow for close mouse placement while still providing the convenience of the numberpad
Completed prototype:
Full Album: http://imgur.com/a/98VRS
Plate recesses:
Full Build Log: http://imgur.com/a/AeGHW
Differences Between the Production Version and the Prototype Pictured above:
- Cerakoted finish on the aluminum plates.
- Plates will be laser cut and then the recesses with be milled to allow for completely square corners on all switch and stabilizer holes (the prototype was cut completely by CNC milling)
- PCB will be provided as part of the kit, so no hand wiring necessary! Designed my skullydazed. Will be running TMK, documentation can be found here: https://github.com/skullydazed/tmk_keyb ... onarch/doc
- Caps Lock and Number Lock LEDs
- Case design slightly modified to accommodate the PCB and the indicator LEDs.
- Additional mounting holes in the bottom plate compatible with GON's Aluminum Feet.
Available Colors:
The aluminum plates used for the top and bottom of the case will be finished using Cerakote which is a very tough and durable ceramic coating often used on firearms.
Three colors will be available for you to choose from including an option for just bare aluminum in case you want to finish the plates your own special way!
Satin Mag:
Burnt Bronze:
Cobalt:
Final Price: $250 (shipping not included)
Order Form: http://goo.gl/forms/2KzgDqXNXY
The above price is for the case and the PCB, and is based on numbers for approximately 25 orders.
If the final order numbers are far below this target of 25 then I will most likely have to adjust pricing accordingly or cancel the buy.
Orders are set to close on November 7, 2015 at this time, however this date is not set in stone.
What is included in the kit:
- Top Plate
- Bottom Plate
- Center Spacer
- PCB
- 12 Machine Screws
- Rubber Feet (4 small and 4 large hemisphereical)
I am more than happy to answer any and all questions you might have!
