Heavier Case for MK TKL Board?
iType
01 Jan 2016, 23:16
Hi folks! Brand new user, first time poster.. and a recent convert from the dim hopelessness of rubber membranes and X-switches.
I'm very interested in an RGB board (either TKL or 60%) and believe I've settled on the MK Disco TKL: https://mechanicalkeyboards.com/shop/in ... ail&p=1540 which, as I understand, is a Ducky-built board. However, I love the idea of having a heavy, sturdy, bulletproof aluminum or steel case. Any chance you folks know of a replacement case I can use for this?
MK's own site lists an aluminum case meant for Filco TKL boards.. and while I can't spot an obvious reason why it wouldn't work, I just don't know enough about what I'm looking at yet.
Thanks very much in advance! :)
01 Jan 2016, 23:57
The aluminium cases on MK are out of stock, unfortunately. I've been looking for a metal case for a Filco/Phantom a while but have had no luck.
Your best bet might be to go for the Varmillo 87 and then getting the aluminium case from Massdrop.
