Sony OA-S3400 Word Processor - Fujitsu Magnetic Reed switches
snuci
Vintage computer guy
14 Feb 2016, 01:06
Here is a vintage word processor from Sony that has Fujitsu magnetic reed switches. I believe HaaTa has one of these (or at least the keyboard) but I'm not sure if he posted the usual amount of photos he normally does. Since there are a few pics in the Wiki (Fujitsu Magnetic Reed - under Cross Reed), I thought I'd post some more pics of the word processor to supplement.
Sony OA-S3400 - Word Processor lid open
Sony OA-S3400 - Word Processor lid open.jpg (227.81 KiB) Viewed 5553 times
Sony OA-S3400 - Fujitsu Magnetic Reed keyboard
Sony OA-S3400 - Fujitsu Magnetic Reed keyboard.jpg (215.42 KiB) Viewed 5553 times
Sony OA-S3400 - keyboard mechanism bottom
Sony OA-S3400 - keyboard mechanism bottom.jpg (245.88 KiB) Viewed 5553 times
Sony OA-S3400 - keyboard mechanism top (it's hard to remove just the key caps!)
Sony OA-S3400 - keyboard mechanism top.jpg (244.61 KiB) Viewed 5553 times
Sony OA-S3400 - key switches
Sony OA-S3400 - key switches.jpg (170.72 KiB) Viewed 5553 times
Sony OA-S3400 - magnetic reed
Sony OA-S3400 - magnetic reed.jpg (310.79 KiB) Viewed 5553 times
Sony OA-S3400 - keyswitch parts.jpg (110.4 KiB) Viewed 5553 times
Sony OA-S3400 - keyboard components
Sony OA-S3400 - keyboard components.jpg (244.92 KiB) Viewed 5553 times
Sony OA-S3400 - keyboard PCB markings
Sony OA-S3400 - keyboard PCB markings.jpg (240.22 KiB) Viewed 5553 times
Sony OA-S3400 - keyboard PCB label
Sony OA-S3400 - keyboard PCB label.jpg (267.94 KiB) Viewed 5553 times
Sony OA-S3400 - key caps
Sony OA-S3400 - key caps.jpg (106.12 KiB) Viewed 5553 times
Sony OA-S3400 - Word Processor lid closed
Sony OA-S3400 - Word Processor lid closed.jpg (210.39 KiB) Viewed 5553 times
HaaTa
Master Kiibohd Hunter
14 Feb 2016, 05:50
:D
This is one of my favourite keyboards. It's too bad the keycaps go a bit shiny (mine was NIB).
I even use it for my avatar!
I've made a controller for this thing, but it's very different compared to other keyboards. It uses a parallel protocol rather than serial. I had to re-wire a couple keys because they didn't handle the press-release signals but other than that, wasn't too bad.
14 Feb 2016, 14:41
I hate you two so much xD .
Beautiful board! What do the switches feel like by the way?
terrycherry
15 Feb 2016, 04:03
Great to see you have the good condition of this rare switch with full case!
mnem
08 May 2016, 03:24
HaaTa wrote: :D
Any chance I could get a copy of your notes? I'm trying to adapt a keyboard to use with a SONY Series 35 Model 10 word-processor that I have no keyboard for and it uses the same physical keyboard as this machine, although I assume with a different encoder since it connects via a RJ-11 connector.
HaaTa
08 May 2016, 06:38
Hmm, with an RJ-11 it's likely completely different.
My old converter code is here -> https://github.com/kiibohd/controller/b ... can_loop.c
I might have a pinout drawing around, but I'll have to dig a bit.
