GMK / Cherry color code question
Madhias
BS TORPE
24 Feb 2016, 17:20
Recently I looked at all my GMK / Cherry keycaps - well I think only three in total - and saw that the caps from my Meto keyboard are not the same beige color like the other caps. I always thought that the beige color is the same, and only recognized now when seeing the caps side by side.
Which color code are the alpha caps of the Meto keyboard? 2M? And all the 'normal' beige sets are always L2? Or are these caps made from Cherry, and the GMK color codes does not apply in this case? Our Wiki article is rather... hey, I could edit it when I have all information I need!
The cap on the top is from the Meto keyboard:
Khers
24 Feb 2016, 17:25
There is yet another beige-ish GMK color called T9 that's the one used on the 60th anniversary keyboards and also the just ran GMK Monkey GB. Maybe that could be the color of your meto?
Madhias
BS TORPE
24 Feb 2016, 23:24
Thanks for that hint, I just looked at some 60th anniversary keyboard pictures, but it is hard to see without comparison. I am not participating in the GMK Monkey 2016 group buy by the way, but it could be nice to be mixed with Skidata caps maybe.
photekq
Cherry Picker
25 Feb 2016, 01:30
Yeah, METO has a slightly different colour scheme I believe. I don't necessarily think that there will be a corresponding GMK colour code.
Madhias
BS TORPE
25 Feb 2016, 09:22
I read that "UN0001 (or white) is T9", which seems to be new from GMK.
Khers
25 Feb 2016, 09:33
Ok, so it's not an additional color after all, nor is it the color of you meto's caps.
Prelim
25 Feb 2016, 11:19
although GMK ony works with that few colors, Cherry Corp. palette was way more vast (in term of beige variations) that why you see so many different OG beiges out there:
I'm pretty sure GMK beige is done with U9/L9 (btw, I find this pic more accurate)
Khers
25 Feb 2016, 12:41
Wow, that's a lot of beige! To me it seems like GMK did a wise selection of colours.
Prelim
25 Feb 2016, 13:18
I think GMK did a good colors choice, but however it's still very limited... custom colors orders shouldn't be needed (like it was in TA set) if they would have a few more options (shades of vivid colors like purple, blue, green, orange, red) like SP have.
xiaodian317
26 Feb 2016, 05:01
It's the G80-3060's (60th keyboard) keyboard.
