Is there a way i can find out which wires are which on the cut cable instead of guessing and connecting random cables? Is it possible to find out where the power and ground is? That way i can guess the rest once i find the power and ground.
Well you have to be careful, if you switch +5V and ground you kill the board stone dead apparently Oo .
Even if I did kill the board, it wouldn't have been too much of a loss. It wasn't a shiny, new Blue Alps board or anything, really. It was just some older Lite-On keyboard that was manufactured by Silitek (guessing by its model number "SK-0002-1U". It had Alps SKCM White switches, generic double-shot ABS keycaps, and a Focus layout. And I bought it for a cheaper price than a new rubber dome board. It sure would've been sad to see it die off by foolish wiring, but at least I would still have the Alps and the keycaps! I wasn't even expecting it to work, anyways, it was in really bad conditionWell you have to be careful, if you switch +5V and ground you kill the board stone dead apparently Oo .
