Hall effect?
elecplus
24 Mar 2016, 20:09
Very old Digital keyboard
Redmaus
Gotta start somewhere
24 Mar 2016, 20:10
Not hall effect unfortunately. Looks like NMB switches of some kind.
elecplus
24 Mar 2016, 20:36
There is a page in the wiki for the VT-100 keyboard but it does not say what the switches are.
24 Mar 2016, 20:45
They're Hi-Tek linears. Electromechanical, not Hall effect. Very stiff.
[ XMIT ]
24 Mar 2016, 20:52
elecplus, these are either Stackpole or Hi-Tek linear switches as Chyros mentioned. I remember that you had a bunch of these in Kerrville. You can see the "praying hands" electrical contacts. You won't see these contacts on a Hall effect board since there are no contacts in those switches. Yes, they are heavy linears.
Yes, these are VT-100 terminal boards. They're not too popular here (or are they? does anyone beside snuci have or want one?) but sometimes vintage computer folks will pick them up.
24 Mar 2016, 21:17
XMIT wrote: elecplus, these are either Stackpole or Hi-Tek linear switches as Chyros mentioned. I remember that you had a bunch of these in Kerrville. You can see the "praying hands" electrical contacts. You won't see these contacts on a Hall effect board since there are no contacts in those switches. Yes, they are heavy linears.
They're Hi-Teks. Stackpole have small "fingers" on both sides; Hi-Teks only have them on one side.
24 Mar 2016, 21:46
Interesting keyboard, too bad it's missing a few keycaps.
Invisius
24 Mar 2016, 22:51
Cool caps, they do look very similar to the Microswitch/early Honeywell boards. I've seen these switches on a Zenith Z-19 terminal before; like Chyros said they're 'bout as stiff as British parliament.
snuci
Vintage computer guy
25 Mar 2016, 02:28
Classic keyboard! I do have a VT-100 keyboard along with the matching DEC terminal. I didn't post any pics because the Wiki has great pics already but might have the Hi-Tek fact missing. The PCB is made by DEC so there's no Hi-Tek label to absolutely identify the key switches.
It's a classic terminal so someone on the "cctalk" mailing list will likely buy it if they need parts.
25 Mar 2016, 09:12
Tbh the Stackpole design is virtually identical to the Hi-Tek one. Hi-Tek even sued Stackpole over it, apparently. Hi-Tek did keep the "fingers on one hand only" design for the Space Invaders switches, though.
