Identify this stem?
FredFloet
29 Mar 2016, 14:18
Hello guys,
I came across this model from cougar which is an "hybrid mechanical" keyboard :roll:. Anyway, after I looked at the swtiches I asked myself if it is possible (theoretically) to replace the keycaps. The used stems looks like alps clones but I'm not really sure. So has anyone of you seen such stems before and can tell me a bit more?
I attached a picture :D
29 Mar 2016, 20:19
There are many different variations of Alps-compatible slider over rubber dome. This looks like one of them where the slider has been made of translucent plastic.
Most of all, it reminds me of this one... which wasn't properly identified.
