wiki: Data Transfer Interrupted
29 Mar 2016, 15:42
Am I the only one who gets a message "Data Transfer Interrupted" while editing the wiki?
:roll:
When this message comes I need to close the browser and restart, otherise even the DT forum does not work. It happens again, after loading some wiki pages.
:o
This bug is independant from my machines (office and home) and independant from the ISP (Telekomedians and Vodafun).
:cry:
[ XMIT ]
29 Mar 2016, 16:31
I have no idea what the root cause is but I have seen some similar issues.
Always compose your posts in a separate editor from the browser to avoid having to re-do work.
29 Mar 2016, 17:37
I have this trouble only since when I came back.
:cry:
29 Mar 2016, 18:25
I have not experienced this, when did you first encounter this 7bit? My last edit was last week I think. Daniel Beardsmore has been massively active on our wiki recently, he should have noticed it but please don't PM him. ;)
29 Mar 2016, 18:49
seebart wrote: I have not experienced this, when did you first encounter this 7bit? My last edit was last week I think. Daniel Beardsmore has been massively active our wiki recently, he should have noticed it but please don't PM him. ;)
It's since about one week, when I came back.
I have the suspicion it happens only if you try to load or edit large wiki pages like R5_leftovers or R6_leftovers .
:roll:
29 Mar 2016, 18:56
I see some relation with https when I search for that error. Possibly related to HTTPS hardening I did when you were away. Maybe in combination with old browsers that have problems with a few ciphers: https://bugzil.la/448303
Could be AES-256.
29 Mar 2016, 19:07
If you use firefox or derivative, go to about:config and type 'security.ssl'. Here you can disable client support for some ciphers, so you can toggle them on/off one by one and find out which one is causing troubles for you.
Here is what our Apache supports:
ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
29 Mar 2016, 19:58
Please order more key caps and other useless stuff, so I can buy some new machines to avoid any further trouble with good old Netscape!!!
:oops:
29 Mar 2016, 20:42
If you know which one your browser negotiates, there's a chance it can be fixed by changing the order in our list.
29 Mar 2016, 21:28
7bit wrote: Please order more key caps and other useless stuff, so I can buy some new machines to avoid any further trouble with good old Netscape!!!
:oops:
:o I hope you're joking 7bit. :roll: Anyway I uploaded ten 1MB images on march 23rd no problems.
Servicehxp
04 Nov 2016, 13:52
This is the first Ive heard of Wiki. How is it different than posting on a forum like this?
Return to “Deskthority talk”
