livingspeedbump wrote: Is there any reason not to have a key where the "RAMA" log is, or allow for buyers to have the option on the PCB to have two 1U keys where the 2U key at the bottom is? The lack of keys does kind of limit the use this can have even as a numpad sadly.
Pulled out the old M0120, and ended up with this:
Unfortunately very uncomfortable for any extended use, which also would limit the usefulness as a gaming pad as well in my opinion.
So while it looks fun and quality seems very good, my concern would be the limited use for numpad and gaming pad+relative discomfort+price may make this a hard sell.
Using it purely as a macro pad would be fine, the software looks great, but again the final price scares me. Anyone can essentially make a macro pad for the cost of a teensy these days.
I understand this, but what I'm getting at is that for $125, being a sub par gaming pad due to comfort, and a sub par numpad makes the price hard to swallow. All I am getting at. The quality of the pad is essentially something you'd
want to leave on your desk and use all the time, especially for TKL and smaller form keyboard users. An extra row up top, or the ability to use 3 keys on the bottom row instead of the single 2U key would really help make it more viable imo.
Hey LSB, in terms of design and logo placement, this is something I will not be changing. From the beginning it was never designed to be a full numpad replacement.
In terms of pricing, I don't know if you realize this or not, but this is
not mass manufactured, it's
batch manufactured (in small quantities) and each enclosure is separately CNC machined
aluminium, on more sides than 2 which involves a lot of rejigging and positions. It is an expensive product to make, each one also has to be primed, coated, then oven baked. And I'm not even turning much of a profit on this, and everything that is profit is split into two. From the start I wanted to make the device as cheap as possible whilst also being high quality/luxurious. I've been from the start looking at ways to add even more value as well. And have spent a lot of personal investment into prototyping and getting things right so that the end-product can be something someone would be proud to have on their desk and use. I'm sorry if this all sounds aggressive, but it's getting a little tiring being told to add more keys or it's "subpar". If I add anything to it, it's no longer going to be the product I set out to make, the M10 (TEN) not the m11, not the m18. I just wanted to show the community something I've been working on, more of a personal project and a foray into doing my first keyboard product and allow people to own one if it's something they're interested in. If it's not for you, then it's not for you, I'm not changing the M10 into something it is not, it's simply a well-made 10-key macropad, that's all! It's not trying to be something it is not. In the future I definitely want to do a bigger board, and probably even end up making a numpad.
Not sure what you where getting at with "anyone could make a macro pad for the cost of a teensy these days", yes they could, and they're welcome to. In fact, anyone could make an m10 themselves, it's entirely open source. There is a whole lot of difference between the two though.
EDIT: apologies for being so defensive
It just gets a little tiring sometimes
gah. Just having a bad day too I guess
Malenky wrote: I'm pretty sure as far as ergonomics go, you shouldn't be resting your wrist on the desk anyway. Also, the whole point is that this is entirely programmable, so you could map mathematical functions to modifiers, but I think if you're using it more as a calculator then maybe a standard numpad or, you know, a calculator, is best for you.
The only thing I would change is that I would (at least like the option to) have the 2u key at the bottom on the left. I would position this to the right of my mouse and could see myself sort of curling my thumb under to hit that key. This is something I do with my left hand on alt, mainly for MMO gaming, so it seems like a pretty natural position to me.
Either way, as I've said before, this is a thing of absolute beauty and I salute you for the design. It's solid without being overly bulky and there is attention to detail while retaining an overall simplicity.
Hey Malenky, thanks heaps for the kind words
I'm glad you understand the products intentions.
I understand the whole left/right positioning thing, and it's hard to choose a location for it and please everyone. It was designed to be used to the left of the keyboard, so you can use the M10 and the mouse at the same time rather than the M10 and a Keyboard at the same time. Ultimately I'd love to do a mirrored version, but it all comes down to cost of production and feasibility :'(
Appreciate the sentiment on the design man, thanks heaps!!
