IBM 1387033
elecplus
25 May 2016, 22:47
I read online that the "unsaver" does not have a delete key. Is this true?
If so, then do you really have to go past the mistake and backspace?
How can you do Ctrl+Alt+Del without a Del key?
25 May 2016, 22:52
Isn't that a delete key in the usual spot? That <- legend, I think, was used for delete way back in early IBM terminal systems.
Seeing this just reminds me of how much I want one of these! Such a gorgeous keyboard.
hammelgammler
Vintage
25 May 2016, 22:54
Yeah I think so too. Would be unusual if there's not delete mapped to the key.
I can totally agree though, Unsaver is my favorite board of all time, but sadly I don't have one.
jeb
25 May 2016, 22:58
I think the key in the delete spot is actually back tab (accessed these days with shift+tab). The key in the lower right of that block may be delete, though? I'm not sure what those symbols mean.
elecplus
25 May 2016, 22:59
I just found a rather poorly done video of one on mashpedia, and yes, it is there. Wonder why the other fellow said there isn't one?
tentator
25 May 2016, 23:02
lol would be funny even if windows still did not exist back then when they created that keyboard! :))))
Halvar
26 May 2016, 08:37
Yes, the key with the striked out a is Delete, the key next to it is Insert. Ctrl-Alt-Del will still be hard to do as there is no Ctrl... :-)
Terminals were different beasts...
The symbols for Insert and Delete are derived from proofreading symbols like these:
http://www.ccc.commnet.edu/writing/symbols.htm
daedalus
Buckler Of Springs
26 May 2016, 17:27
A with Hat = Insert
A with squiggly line = Delete
One simply does not Ctrl-Alt-Delete a mainframe ;)
26 May 2016, 17:32
Heaven forfend that DOS nonsense!
26 May 2016, 17:36
All hail the mighty DOS, its a shame IBM whet with dos when they could have gone with CP/M (or is is CP\M i forget now).
26 May 2016, 17:40
Ach! Microsoft really got its tentacles deep in your mind if you can so easily mistake \ for that.
26 May 2016, 17:52
Muirium wrote: Ach! Microsoft really got its tentacles deep in your mind if you can so easily mistake \ for that.
Hey i use UNIX all day In work !
Apple UNIX , guaranteed to have at least 25% more untested crap that does not work than your leading competitor.
Apple: ignoring power users on OSX since 29th June 2007
26 May 2016, 17:55
Whatever. Only Microsoft went with backslash for directory separators just to spite the world. The web went the UNIX way, the right way, because Tim Berners-Lee was using NeXT, not DOS or Windows.
26 May 2016, 17:58
Muirium wrote: Whatever. Only Microsoft went with backslash for directory separators just to spite the world. The web went the UNIX way, the right way, because Tim Berners-Lee was using NeXT, not DOS or Windows.
i wonder if MS used \ or / in Xenix
26 May 2016, 17:59
Oh boy, this thread just turned into an OS war.
26 May 2016, 18:00
Not an OS war. But a very specific skirmish about / and \ !
26 May 2016, 18:02
\ is on a nice big key in the ANSI layout , easy to get to see. / does make more sense however.
I vote we need a quota on the web, 50% / and 50% \ , its only fair right?
Wodan
ISO Advocate
26 May 2016, 18:04
My favourite part about this is having to replace \ with / when using windows paths in Java coding ...
Rich source of stupid errors ...
26 May 2016, 18:07
Even worse, \°°/. :mrgreen:
alh84001
v.001
27 May 2016, 00:23
Some nice info on the rationale behind path separator in Win and DOS - https://blogs.msdn.microsoft.com/larryo ... character/
@Wodan just don't tell me there are String constants in code :) That's what File.separator is for.
y11971alex
02 Jun 2016, 16:39
daedalus wrote: A with Hat = Insert
But you can Big Red Switch it. :shock:
elecplus
03 Jun 2016, 18:58
Finding these things is like pulling hen's teeth! There might be hope yet. Should know by Monday.
03 Jun 2016, 19:02
elecplus wrote: Finding these things is like pulling hen's teeth! There might be hope yet. Should know by Monday.
If anyone but you said that I would not give one cent. Again, and again and again:
thank you for your efforts Cindy!
hammelgammler
Vintage
03 Jun 2016, 19:22
Yeah if anyone can find an Unsaver with a reasonable propability then it's Cindy. I remember that huge stack of SSK months ago.
03 Jun 2016, 19:33
The NIB SSK haul? That was 2014 as I recall. (Had to wait until early last year to get my hands on mine, via luggage.) Time flies, like SSKs do!
elecplus
03 Jun 2016, 19:35
Yes, it was 2014 :-) Hard to believe I closed the warehouse a year ago.
I am trying real hard to make this the year of the unsavers, 4704s, and beamsprings.
I will keep trying :-)
Britney Spears
04 Jun 2016, 08:03
Wodan wrote: My favourite part about this is having to replace \ with / when using windows paths in Java coding ...
Is there a good reason not to use the built-in abstraction for this problem?
I'm not a Java developer but is use it in Node.js all the time.
Edit: I see that alh84001 has already posted this. Damn!
