MacCharlie - Apple M0110 with a PC extention
snuci
Vintage computer guy
09 Jun 2016, 02:28
I saw a Dayna MacCharlie recently on eBay and that reminded me about something you might like to see.
The Dayna MacCharlie is very rare add-on to the Macintosh 128k that allows the Mac to run MS-DOS. From the pictures below, you can see the main unit with the dual disk drives. This has an 8088 based motherboard in it and connects to the Macintosh via a serial cable. The Mac runs what is essentially terminal software that starts a session to the MacCharlie unit and runs DOS in a window. It's an early version of a physical virtual machine (if that makes sense).
The normal Apple M0110 keyboard doesn't have enough keys to work as a proper PC so Dayna added a keyboard enclosure that adds the extra keys. The M0110 plugs into this Dayna keyboard extension and the extension then plugs into the Mac. The construction of this enclosure is almost identical to the M0110 including the same Alps SKCC key switches. Anyway, here are some pics.
MacCharlie - keyboard extention slightly removed
MacCharlie - keyboard extention slightly removed.JPG (233.15 KiB) Viewed 8431 times
MacCharlie - keyboard complete
MacCharlie - keyboard complete.JPG (208.01 KiB) Viewed 8431 times
MacCharlie - keyboard extention over Apple M0110 keyboard bottom
MacCharlie - keyboard extention over Apple M0110 keyboard bottom.JPG (229.26 KiB) Viewed 8431 times
MacCharlie - keyboard extention key switches
MacCharlie - keyboard extention key switches.JPG (337.48 KiB) Viewed 8431 times
MacCharlie - key caps almost the same as Apple
MacCharlie - key caps almost the same as Apple.JPG (243.02 KiB) Viewed 8431 times
MacCharlie - complete unit
MacCharlie - complete unit.JPG (203.22 KiB) Viewed 8431 times
MacCharlie - keyboard extention over Apple M0110 keyboard top
MacCharlie - keyboard extention over Apple M0110 keyboard top.JPG (236.57 KiB) Viewed 8431 times
Redmaus
Gotta start somewhere
09 Jun 2016, 02:29
Mind = Blown
09 Jun 2016, 02:34
I've read about this one before, but only seen it in print ads. What a weird product! First time I've seen the keyboard photographed properly. Well done and thanks for that.
Does yours work? If so, care for a picture of the Mac running something in a DOS window? Some pictures of the MacCharlie keyboard by itself would be interesting, too. Shows just how weird it is.
snuci
09 Jun 2016, 02:39
Muirium wrote: Does yours work? If so, care for a picture of the Mac running something in a DOS window?
Thanks. Yes, it works. I will have to remember how to hook it up but I'll try to take some more pics tomorrow once I have better light.
livingspeedbump
Not what they seem
09 Jun 2016, 03:20
Whoa. what a find.
I've never actually seen one of these things before.
LewisR
09 Jun 2016, 05:09
Wow, cool! I too would love to see it in action!
09 Jun 2016, 09:20
Talk about a functional idea! It's a TKL "adapter" done what 25 years ago? Brilliant. Looks good too.
Muirium wrote: Some pictures of the MacCharlie keyboard by itself would be interesting, too. Shows just how weird it is.
Yes please!
snuci wrote: Better get this in before Seebart does ;)
deskthority-f17/post-your-deskthority-h ... ml#p313288
:mrgreen:
09 Jun 2016, 12:16
Wow, that's fantastic! Finally it becomes a normal keyboard! :D
derzemel
09 Jun 2016, 12:20
so... a keyboard docked in a keyboard... I want a modern version :D (60-65% for the go and the rest for the work :P)
gcardinal
09 Jun 2016, 13:45
Im here just to post 'wow'!... ok all, done!
ps: amazing find
ramnes
ПБТ НАВСЕГДА
09 Jun 2016, 14:58
Ahah, awesome!
Touch_It
09 Jun 2016, 16:32
Giving the middle finger to 60% boards. LOVE IT!
09 Jun 2016, 17:00
More like the paper…
snuci
09 Jun 2016, 23:41
Here's a couple of quick pics of the MacCharlie running. The first pic is the MacCharlie Macintosh boot disk. It has a MacCharlie application that you launch that communicates with the MacCharlie.
MacCharlie - Mac boot disk
MacCharlie - Mac boot disk.JPG (199.29 KiB) Viewed 8225 times
Once the MacCharlie Mac application runs, it boots up the MacCharlie unit and you see the familiar Phoenix BIOS and memory count to 640k. After it does this twice, if loads MS-DOS 3.1 in this case and you are off to the races.
MacCharlie - DOS prompt
MacCharlie - DOS prompt.JPG (248.02 KiB) Viewed 8225 times
Voila! A PC on your Macintosh! The menus in the MacCharlie application allow you to transfer Mac files to the PC and PC files to the Mac which was unheard of at the time. It is a pretty cool unit.
The name "MacCharlie" comes from a play on words. Charlie Chaplin was the spokesperson for the IBM PC so Dayna called it the "MacCharlie" whose logo showed the transformation of the Macintosh logo into a Charlie Chaplin hat like this:
"About MacCharlie" dialog box
More info on the MacCharlie (and where this last image came from) here: http://www.vintagemacworld.com/charlie.html
HzFaq
09 Jun 2016, 23:46
Great find dude.
katushkin
13 Jun 2016, 04:48
Incredible looking thing. Fantastic to see it's still working.
LewisR
13 Jun 2016, 23:37
That's definitely the most interesting classic Mac setup I've seen.
ideus
14 Jun 2016, 14:57
This is very cool, thank you for sharing.
snuci
14 Jun 2016, 16:34
Thanks guys. This was going to be my Deskthority awards "Most awesome find" entry. I guess I was a little early ;)
14 Jun 2016, 17:03
snuci wrote: Thanks guys. This was going to be my Deskthority awards "Most awesome find" entry. I guess I was a little early ;)
It's a very strong candidate for DTA6 I can tell you that.
