Eastern community announed another kind of metalic board
TriGemComputer
29 Oct 2011, 14:50
KMAC [ 케이맥 Keyboard_Mania_Attic_Craft ]
http://www.kbdmania.net/xe/3118632
Thanks_Kim_J_Y-M_R_S_JJ 001.jpg (233.97 KiB) Viewed 4198 times
Thanks_Kim_J_Y-M_R_S_JJ 002.jpg (257.25 KiB) Viewed 4198 times
Tomorrow !!
TYPE 1 : 케이맥 Winkeyless Silver
TYPE 2 : 케이맥 Winkeyless Titan
TYPE 3 : 케이맥 Winkey Silver
TYPE 3 : 케이맥 Winkey Titan
-PCB, Elements all welded
-Alu, Plate, incl, Bolts
-Alu, Upper/Lower casing, incl, Bolts
-Alu, Legs
Price: 280,000 KRW
4Ss (Switch/Spring/Stabil/Sticker) not included, but there will be another group buy
Keytops, LEDs, Cable.. up to you.
This is a 1st KMAC and probability of successions (2nd and so on) kind of high he says..
bye, by guys..
29 Oct 2011, 17:23
This looks much better than the earlier prototypes.
Grond
29 Oct 2011, 18:25
I wish they were Filco metal cases!
fossala
Elite +1
29 Oct 2011, 18:29
I like the metal cases that are coming out but I think $250 on a case is a bit excessive. Even the tiny poker one that is only a base rather than a case was $140.
Grond
29 Oct 2011, 18:56
PCB is not included in the 250$?
fossala
Elite +1
29 Oct 2011, 18:59
I don't understand Korean but all the pics don't show any pcbs.
Grond
29 Oct 2011, 19:09
Well, I think other costum keyboards went for $400+ without switches, so maybe it's actually 250$ for the case only. That's very expensive indeed. It's a shame companies like diatec don't produce metal keyboards on their own, that would be much cheaper with mass production.
ripster
29 Oct 2011, 19:31
Grond
29 Oct 2011, 21:40
I had seen that on GH, but it was a limited edition, wasn't it? I don't like the overall design, but the integrated wristrest may be a neat idea. I also wonder why they opted for this clustered layout instead of regular tenkeyless.
TriGemComputer
29 Oct 2011, 23:56
-PCB incl. (as i said all elements are welded)
-CapsLock keytops, you can use both Cherry's and Maje's
-Spacebar, Ditto
-All elements are on the rear side of PCB
-detachable USB connector or not
-Switch Imbeded diode or PCB welded
-Signal response time configurable
-F1-F12, twelve, Hardware macro keys
-F1-F12 LEDs for macro
-All keys are remappable (own mapping program)
-W/A/S/D LEDs (individual on/off)
-Do not need ISP loader
-you define Keybinary (64bit OS supports too)
-Capslock/LCtrl swap
-ESD safe
-Apple Mac's FN key use
(followings are coming with next PCB version)
-USB/PS2 swap (just plugin)
-NKRO (PS/2)
TriGemComputer
30 Oct 2011, 00:23
This time just 100 boards only.
It is NOT a big deal and NOT a chiiiip ones which you eager 4.
4.g.e.t. i.t.
TriGemComputer
30 Oct 2011, 07:36
http://www.kbdmania.net/xe/3121518
Never mind. It has gone.
-It took 90 minutes to go there.
See you.
Return to “News”
