Silver badge Model M's from 1992?
Engicoder
16 Jun 2016, 23:57
I recently noticed that one of the Silver badge Model M's that I have is dated 1992. The internal plate is marked with a 1992 date. There is even a 1992 date printed on the back side of the upper half of the case. I am not very knowledgeable in Model M's but it was my understanding that only earlier M's had the square silver badge. This board is a terminal board which may factor into it. I can take some pictures if need be.
17 Jun 2016, 00:01
Engicoder wrote: This board is a terminal board which may factor into it.
That would be my guess also. Let's see your pics.
clickykeyboards
17 Jun 2016, 00:06
The latest silver label model M's that I recall were from 1996.
https://web.archive.org/web/20141011225 ... /id/156756
Engicoder
17 Jun 2016, 00:18
That is an interesting lot of '131s. All such low ID numbers. I wonder if they were custom ordered.
clickykeyboards
17 Jun 2016, 00:25
Its been a few years since I found them, but I too was surprised that the numbers were all in the same range.
IBM was very careful to assign unique ID numbers from 1985-1992.. but in later years, there were duplicate numbers assigned as Lexmark cared less and less...
17 Jun 2016, 01:59
That was a very "short run" of 1390131s in the 1990s, wasn't it?
Do they have the heavy internal plates?
clickykeyboards
17 Jun 2016, 02:49
I have only seen the thicker internal "shiny" metal plates on 1985, 1986 and on early 1987 model M's
For example, 1987 IBM model M (1390131) from 27 MAR 87 http://clickykeyboards.com/product/ibm- ... 27-mar-87/
