What is the UK version of the 1390131?
28 Jun 2016, 22:47
Simple question really, does anyone know the part number of the UK equivalent of the '0131 (1st gen non-XT square-badge rainbow-plate)? I find it hard to find any sources Oo .
elecplus
28 Jun 2016, 22:54
28 Jun 2016, 23:05
elecplus wrote: 1391406? https://www.preater.com/modelm/
That's the equivalent of the 1391401 ;) .
29 Jun 2016, 00:48
When did Greenock come online?
Is there a UK parallel to the 1390120?
29 Jun 2016, 03:02
fohat wrote: When did Greenock come online?
Yes, that should be the 1389969, which I added to wikipedia a while ago (it's the UK-layout XT model). There are a whole bunch of completely conflicting statements on Model M part numbers between our wiki and wikipedia though. If the 0120 is the US XT version, it's the UK counterpart of that.
I don't know when Greenock came online, but it must've been extremely early as my early-production 1388032 (the one built with prototype parts) should be from there.
emdude
Model M Apologist
29 Jun 2016, 03:11
According to the below video, it appears that Greenock came online in 1954, so a long long time ago:
29 Jun 2016, 03:23
I can't find the 1389969, but the XT is nothing like the Model M.
The 1380363 in the wiki looks exactly like the 1390120 because it has no LEDs.
The 1388032 looks like an industrial version of the 1390131 (with LEDs).
From my personal experience, the only visible difference between 1390120 and 1390131 are the LEDs.
All the keyboards in the wiki are ANSI, are some of yours ISO?
29 Jun 2016, 10:20
I don't mean Model F XT, I mean the XT-compatible Model M. It didn't have lock lights because the XT protocol doesn't support them.
This should be a 1389969. I spotted one on eBay a few weeks ago, it came with a 5150 system and it had the label still on it, so it was easy to identify properly.
I have never seen the UK counterpart to the 0131 though, which is obviously AT and does have the lock lights. It should exist, but I've never seen a trace of it. Hopefully someone here has one :) .
The 1386303 is quite different from the 0120; it's a terminal keyboard (it precedes the AT connector) and has a different numpad.
The 1388032 precedes the 0131 so technically it's the other way around but yeah, the 1388032 is the industrial 0131.
All the UK model Ms I have are 1406. I also found a 1394324 a while ago, as well as a batch of ten Unicomp 58.036 rubber dome Model Ms.
29 Jun 2016, 14:29
I have never owned a 1390120, does it have an XT/AT or other DIP switch?
29 Jun 2016, 14:51
I'm not sure tbh. What I've read almost suggests the board is somehow simultaneously XT compatible, but I don't see how that would work.
29 Jun 2016, 14:58
29 Jun 2016, 17:10
Found it, ironically on Geekhack :p .
I figured if the 1391406 is the UK version of the 1391401, maybe the UK version of the 1390131 is called 1390136. And apparently that was the case! :)
Here's the post showing it:
https://geekhack.org/index.php?topic=39786.0
I'll add it to the list on wikipedia soon.
clickykeyboards
29 Jun 2016, 20:16
I have an original IBM XT with the original boxes and manuals and it came with a 1390120 keyboard and it worked natively with the XT computer.
I was also able to connect the 1390120 with a 5-pin DIN to ps/2 adapter and a ps/2 to USB converter and use it my modern 2016 computers without needing to flip any physical external or internal DIP switches. My guess is that the internal keyboard controller in 1390120 is capable of auto-switching between XT/AT keyboard codes.
http://www.clickeykeyboards.com/model-m ... m-model-m/
IBM Personal Computer XT and 1390120 keyboard
ibm xt 1390120.jpg (454.59 KiB) Viewed 3779 times
29 Jun 2016, 20:42
Cool stuff, good to know! :) Updated the wikipedia page accordingly.
clickykeyboards
30 Jun 2016, 02:49
Chyros wrote: Cool stuff, good to know! :) Updated the wikipedia page accordingly.
Great job on editing the wikipedia page.. I've been watching that wikipedia page since it was originally created in 2004 and have been happy to see more and more user-submitted content and history added to the page.
https://en.wikipedia.org/w/index.php?ti ... d=12323803
..and I hope one day someone in the community finally decides to remove the
"This article needs additional citations for verification. Please help improve this article by adding citations to reliable sources. Unsourced material may be challenged and removed. (November 2008) (Learn how and when to remove this template message)"
30 Jun 2016, 03:24
Who removed my SEO link??? Bastards. :evil:
https://en.wikipedia.org/w/index.php?ti ... =404130123
