Royal / Triumph Adler Alphatronic PC
snuci
Vintage computer guy
16 Jul 2016, 00:26
Here is a Royal / Triumph Adler Alphatronic PC from 1984. I wish this was a better keyboard example because you can clearly see rust on the switch plate but I am considering restoring this plate and re-painting it. This is a fairly rare computer with a low profile keyboard with Futaba low profile linear switches.
Here are some pics:
Royal TA Alphatronic PC - computer front
Royal TA Alphatronic PC - computer front.JPG (297.18 KiB) Viewed 3828 times
Royal TA Alphatronic PC - computer back
Royal TA Alphatronic PC - computer back.JPG (267.84 KiB) Viewed 3828 times
Royal TA Alphatronic PC - key cap profile
Royal TA Alphatronic PC - key cap profile.JPG (314.65 KiB) Viewed 3828 times
Royal TA Alphatronic PC - keyboard mechanism
Royal TA Alphatronic PC - keyboard mechanism.JPG (235.21 KiB) Viewed 3828 times
Royal TA Alphatronic PC - keyboard pcb back
Royal TA Alphatronic PC - keyboard pcb back.JPG (347.49 KiB) Viewed 3828 times
Royal TA Alphatronic PC - keycaps removed
Royal TA Alphatronic PC - keycaps removed.JPG (247.57 KiB) Viewed 3828 times
Royal TA Alphatronic PC - rusty plate
Royal TA Alphatronic PC - rusty plate.JPG (521.77 KiB) Viewed 3828 times
Royal TA Alphatronic PC - Futaba switch profile
Royal TA Alphatronic PC - Futaba switch profile.JPG (256.83 KiB) Viewed 3828 times
Royal TA Alphatronic PC - Futaba switch side
Royal TA Alphatronic PC - Futaba switch side.JPG (210.19 KiB) Viewed 3828 times
Royal TA Alphatronic PC - PC dated ICs (1984)
Royal TA Alphatronic PC - PC dated ICs (1984).JPG (387.74 KiB) Viewed 3828 times
Royal TA Alphatronic PC - double shot low profile key caps
Royal TA Alphatronic PC - double shot low profile key caps.JPG (186.04 KiB) Viewed 3828 times
16 Jul 2016, 00:45
Cool stuff as usual snuci, I just stumbled over this official TA Triumph-Adler page about the history of the alphatronic series.
http://www.triumph-adler.com/C125713A00 ... 0E00695A08
LewisR
16 Jul 2016, 01:07
I think the design idea of the circle around the number with the orange F-keys is interesting and aesthetically pleasing. I am assuming those would function as F-keys anyway.
snuci
16 Jul 2016, 01:14
LewisR wrote: I think the design idea of the circle around the number with the orange F-keys is interesting and aesthetically pleasing. I am assuming those would function as F-keys anyway.
I agree with you. I like that idea. It's hard to see but there is also a small "channel" above the function keys. Looks like a plastic label holder might have fit there to define what the keys do. I've seen this idea done with overlays on other keyboards of the era so those keys could be labelled anything. There is a cartridge slot hidden at the top right (there is currently a Micro Text cartridge in it). No labels were with it though.
terrycherry
16 Jul 2016, 02:28
It's unusual another keyboard having this switch!
Could you mind solder the switch to see which having the Futaba logo on the base?
My keyboard having the clone of it(black lock tab, original Futaba low-profile linear is the white lock tab)
snuci
17 Jul 2016, 15:53
terrycherry wrote: Could you mind solder the switch to see which having the Futaba logo on the base?
Hi Terrycherry,
Sorry, couldn't get to it yesterday. Here's a pic. No logo.
Royal TA Alphatronic PC - Futaba switch bottom
Royal TA Alphatronic PC - Futaba switch bottom.jpg (162.3 KiB) Viewed 3735 times
snuci
17 Jul 2016, 17:04
A couple of more pics here (I am terrible at these internal pics) but this does seem different than the current one in the Wiki. This one has two leaf pieces where the wiki version seems to only have one. This also was fused together where the hole was at the bottom and was kinda difficult to pull apart. You can see some debris on both sides.
Royal TA Alphatronic PC - Futaba white plastic rear cap
Royal TA Alphatronic PC - Futaba white plastic rear cap .JPG (241.57 KiB) Viewed 3723 times
Royal TA Alphatronic PC - Futaba low profile linear internals
Royal TA Alphatronic PC - Futaba low profile linear internals.JPG (247.32 KiB) Viewed 3723 times
Royal TA Alphatronic PC - Futaba low profile linear metal leafs
Royal TA Alphatronic PC - Futaba low profile linear metal leafs .JPG (259.24 KiB) Viewed 3723 times
Note: the leads also unscrewed and looked like the leads in the Wiki so I didn't take a picture of those.
17 Jul 2016, 17:39
Switch internals and close ups are though to shoot, good work!
tigpha
17 Jul 2016, 17:46
I see a face, two thumbs up and blowing a raspberry! Sorry, couldn't resist.
snuci wrote: Image
terrycherry
18 Jul 2016, 07:37
Thanks your switch internal photos. I got to see my switch later.
