NEC APC-H412 review (NEC blue ovals)
31 Jul 2016, 17:50
After many many requests to review blue ovals, here it finally it; an NEC APC-H412, with Cindy's favourite switches! Hope you enjoy! :)
31 Jul 2016, 18:24
Good work T., once again you show good taste in keyboards ;) , one of the first boards I bought here at DT:
wiki/NEC_APC-H412
31 Jul 2016, 19:12
Haha thanks, yeah it's definitely a very nice piece of hardware :) .
31 Jul 2016, 19:16
I still do not understand why mine is soooo pingy? I see you have two there, what's the ping-factor? I know XMIT aslo has quite a bit of experience with this keyboard.
31 Jul 2016, 19:46
seebart wrote: I still do not understand why mine is soooo pingy? I see you have two there, what's the ping-factor?
It's high xD . Not Pingmaster high, but definitely noticeable.
31 Jul 2016, 19:57
Yes thanks for confirming that, basically the only negative point of an otherwise excellent keyboard. NEC ovals are underrated, a far better experience than quite a few other switches. I was thinking about some rubber or foam to dampen that ping, never got around to it like a lot of stuff.
elecplus
31 Jul 2016, 20:37
Well done! I think you are the only person I know that uses their index finger to hit the space bar :)
Maybe more people will appreciate this wonderful keyboard now.
31 Jul 2016, 20:42
elecplus wrote: Well done! I think you are the only person I know that uses their index finger to hit the space bar :)
Thanks! :) Yes, I know, I use the index finger very often, a lot of people have remarked that xD . I do use the thumb sometimes normally, but because of the way the camera blocks the typing path, I'm restricted to using the index finger in the videos :) .
jacobolus
01 Aug 2016, 10:29
The pre-click actuation is a terrible anti-feature. Renders these switches unusable for me.
Return to “Reviews”
