I fckd up a spring on my Model M, are replacements same?
Lynx_Carpathica
11 Aug 2016, 17:45
Hi guys! I destroyed the spring on my right arrow, and I want to replace it.
I found a person, who could give me a hammer+spring assembly.
But we don't know if it would fit.
Do all Model M's use the same hammer?
It's a 1391403.
PS: I don't want to explain how I did it :P :oops:
Halvar
11 Aug 2016, 17:51
AFAIK yes. Just check that they're from a genuine IBM, Lexmark or Unicomp Model M, not a Model M2 or F.
ramnes
ПБТ НАВСЕГДА
11 Aug 2016, 17:52
I have the same problem, but for a 5576-003. Who can help me? :mrgreen:
Lynx_Carpathica
11 Aug 2016, 17:57
Thanks, Halvar!
Two birds with one stone - I will also have to boltmod it :D
[ XMIT ]
11 Aug 2016, 18:01
You don't need to do a bolt mod to replace a spring. You can replace it "top side" by using a wooden toothpick. Insert the toothpick, rotate to get the spring to "bite" on to it, and then pull the old spring off and put the new one on by rotating. I generally rotate counter-clockwise.
If you have a few hammer and spring assemblies handy, you can practice some before you do the actual repair. Of course you can do a bolt mod too but that takes hours and replacing it with a toothpick takes minutes.
Lynx_Carpathica
11 Aug 2016, 18:30
Yeah, you might be right. Can you make a video on it? I want to see it, it's just hard to imagine.
Lynx_Carpathica
11 Aug 2016, 18:33
Lynx_Carpathica wrote: Yeah, you might be right. Can you make a video on it? I want to see it, it's just hard to imagine.
EDIT: So I don't need to actually replace the hamer, just the spring?
Hmm let me try to swap the thing with the scroll lock key.
alh84001
v.001
11 Aug 2016, 19:17
Well, I put some M springs in my M2, and it seems to be working fine, so I would assume it would work vice-versa as well. Model F is adifferent story.
As for hammers, do we know all the colors there are? I know three - black, white, (milky?) brown.
[ XMIT ]
11 Aug 2016, 19:18
Yeah, just the spring, you can pull the spring off of the hammer with a toothpick. I'll see about getting a video...
Lynx_Carpathica
11 Aug 2016, 20:01
Yeah, just the spring, you can pull the spring off of the hammer with a toothpick. I'll see about getting a video...[/quote]
I pulled off the spring from the scroll lock, and well, it got bent a bit, but it still works. I can navigate comfortably, so it will do for now. There is no srping on the SL button. Don't use that anyway. I will replace that soon.
11 Aug 2016, 20:03
Why is Sandy55's "Chopstick of Death" always so hard to find?
And somebody on Geekhack a couple of years ago created a really elegant method using a 1/4" pop rivet.
Lynx_Carpathica
11 Aug 2016, 20:20
it was easy to find.
but very hard to execute. and i failed.
i got bored and pulled of the spring.
wobbled
12 Aug 2016, 03:12
I managed to replace springs by using a torx driver that i put in to the springs coil then pushed down to seat it on to the hammer, they're fairly easy to replace but can take a while to get it seated perfectly.
Lynx_Carpathica
12 Aug 2016, 10:32
Removing was a nightmare, reseating it was eays...er. :D
