A Confusing issue with TMK Firmware
Trexation
12 Aug 2016, 16:35
Recently I have started working on a special input system for a local public project. I have chosen to use a teensy 2.0 and a tmk's keyboard firmware as the basis of my project but I have run into issues with N key rollover.
Specifically only 6 of the 7 total keys will every register at one time. I have tested extensively and each key works individually, but when I try to trigger all 7 keys at once it does not register one key. Normally the key that does not trigger is the D key but not always. when I test the tester by pressing more than 7 keys on my 910 they all register correctly so the testing software is not the issue.
Here is the links to the keyboard hex file calculator and related stuff.
Hex Generator - http://kb.sized.io/
Keyboard Generator - http://www.keyboard-layout-editor.com/#/
Tester Page - https://www.microsoft.com/appliedscienc ... gDemo.aspx
Thank you for any help provided
customkeyboard.zip
The .zip with all the code
(5.53 MiB) Downloaded 90 times
bentglasstube
12 Aug 2016, 22:19
I may be mistaken, but I think that TMK over USB uses the standard USB HID descriptors which can only send six keys at a time. Your links don't show anything more than the tools that you are using, so I'm not sure what you are actually trying to do, and this is just a guess as to what your issue might be.
