Attempt to recreate a TypeMatrix-2030
Kurk
07 Nov 2011, 22:28
Hi there, I'm new here :?
I'm typing on a TypeMatrix-2030 (first generation) in Dvorak for several years now and I have grown attached to its matrix layout. While it has quite decent double-scissor switches, I was wondering how a mechanical version would be. So I got a (two, actually) Tipro MID-AM-KM128A-016 programmable POS keyboard (with Cherry blacks) from ebay and gave it a go.
original tipro: Image
Rearranged the keys to TypeMatrix layout and programmed the controller. Then I had to print, cut and insert all paper labels for the re-legendable key. Annoying work :shock: Sorry, no picture of this stage.
Unfortunately, these flat keys just aren't made for typing - it was horrible. So I replaced the letters with keycaps from another board. Well, somewhat better but QWERTY keycaps arranged in Dvorak layout make for a bumpy typing experience :(
with QWERTY keycaps:Image
Finally, the QWERTY keys got ditched and I inserted some blank keycaps (blue POM jelly caps):
Here's the more or less final version:Image
My verdict so far:
OK for fun but not for serious typing because:
-Cherry Blacks are not my favorite switches...
-the segmented space bar (all the 10 keys) is kind of annoying
-<enter> and <backspace> (the yellow 1x2 keys) span two switches which makes them hard to press
On the plus side:
+matrix layout :ugeek:
+completely programmable in 4 layers. The small, green key in the lower left corner activates layer 2, a numpad. Also, cut, copy, past, Alt-Tab and Win keys.
Cheers!
Minskleip
07 Nov 2011, 22:33
Cool! But needs awesomer keycaps. These are my Tipros: Image
Notice the space and back space keys.
You can buy from the Group 4 mass order 8-)
07 Nov 2011, 23:11
Nice Tipros there :mrgreen:
Kurk
09 Nov 2011, 20:51
Minskleip wrote:Cool! But needs awesomer keycaps. ...
Yes indeed, I need better caps. But it's rather hard/expensive to get Dvorak or non-sculpted ones.
Your caps are verrry nice; do they have a sperical top?
But the switches are more important. Do you guys know if there are POS/matrix boards with Cherry switches other than black?
-Kurrk
hoggy
09 Nov 2011, 21:27
Nice. I've seen pos boards with 4 switches under a cap - takes a lot of effort to press those down... You're better off with the separate keys for the spaces.
Kinesis advantage - browns (or reds - special order) - not cheap, but I love mine.
Most cherry pos keyboards are plate mounted, so you can't even do a stem swap.
I know devlin do some keyboards with cherry browns, but I don't know if all of their cherry switch boards are (and beware that some of them are re-branded alphameric - and they aren't all that nice).
Minskleip
09 Nov 2011, 21:30
-Kurrk
Nope, plain new cylindrical. They're from the Round 3 mass order. Black Cherries as well.
22 Nov 2011, 18:49
Kurrk wrote:(...) Do you guys know if there are POS/matrix boards with Cherry switches other than black?
-Kurrk
hoggy
22 Nov 2011, 20:39
Drat. I've managed to curtail my desire for new items for a while now...
Ascaii
The Beard
23 Nov 2011, 11:50
if anyone wants a jarltech I have a few lying around that I dont need.
Ekaros
23 Nov 2011, 11:57
That looks cool. I realy need to get job and start wasting money after next summer, on other hand I require stuff to work under Win 7 nowdays, no luck with X-keys I had...
Kurk
24 Nov 2011, 22:18
Ah, that's surely looking nice! Actually, I secured a Jarltech matrix board, too. Unfortunately I had to send it to my parents due to postage costs. So I have to wait till christmas to see what switches are hidden beneath its caps :cry:
Inf3rn0_44
24 Jan 2012, 16:03
Hey can you let me know more information about those (blue POM jelly caps) keycaps? Thanks
Icarium
24 Jan 2012, 23:35
Ascaii wrote:if anyone wants a jarltech I have a few lying around that I dont need.
Do you still have some?
Kurk
25 Jan 2012, 22:05
Inf3rn0_44 wrote:Hey can you let me know more information about those (blue POM jelly caps) keycaps? Thanks
I got them from an eBay seller (watch-buy-save11); this should be the item: http://www.ebay.com/itm/Blue-37-Pcs-Rep ... 2198wt_754.
To be honest, I haven't used them much yet so I can't tell you if they are suitable for every day use. They do feel cold and rather smooth, almost slippery. That's why they are called jelly caps obviously...
Here are two pictures side by side with ordinary Cherry caps.
