I'm trying to find a keycap replacement guide that would explain how to replace the shift key and other long keys that have the bars under them.
I was hoping to find a sticky thread here, but I don't see one (I hope I didn't miss it).
I googled "mechanical keyboard keycap replacement" and found a couple of lengthy YouTube videos, but they seem not to address the long key problem.
What happened is that I removed some of the keycaps on my Rosewill for cleaning purposes, and then discovered I don't know how to replace the long ones.
thanks, Mike
keycap replacement guide?
- fohat
- Elder Messenger
- DT Pro Member: 0158
I don't have a Rosewill any more, but often you will need to use a small screwdriver in one hand to push or guide the parts underneath while seating the primary key from above.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
- kbdfr
- The Tiproman
Don’t know about Rosewill specifically, but in my Cherry keyboards the difference is just the bar length.
