Here is my layout:
Direct link -> http://www.keyboard-layout-editor.com/# ... 2e280b70b1
Firstly, I'm unsure of the dimensions of a switch hole that can accommodate a two-switch 2u keycap OR a one-switch+two-stab 2u keycap. If I knew exactly which type of keycaps I could get then I'd design the switch plate file to fit the right kind.
Secondly, I would also like to get a complete set of keycaps. I *wish* I could get it in cherry profile Carbon, but I believe I'm priced out of that option considering the number of special keys (outside of a base set) that I would need to complete the set.
Failing that, a straight black keycap with white legends would work, or blanks for the oddly sized modifier keys.The center keys, combined with the total number of 2u keys is highly unusual, and so would need to be specially sourced.
Any help, suggestions or support will be greatly appreciated. PS. I'm often idling on the freenode IRC channel. Ciao!
