KEYTRONICS KB3270 PLUS PROFESSIONAL SERIES MICRO-TO-MAINFRAME KEYBOARD
Battlefieldium
- Main keyboard: Ozone StrikeBattle Brown MX
- Main mouse: Logitech G502
What switches are these, im not having any luck on google. I found one for 325 USD on Ebay but it does not really specify the switches. And are these really that expensive?
Im asking because of someone near me is selling but the info is kinda low, so im looking for any kind of information about this keyboard.
- Screenshot_20160911-234347.png (2.33 MiB) Viewed 4827 times
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
325 is WAY too expensive. 25 should be more like it. Keytronic had three switches that we know of:
wiki/Category:Key_Tronic_switches
None of them are really great although Key Tronic magnetic reed is interesting. That keyboard will likely have Key Tronic dome with slider or Key Tronic foam and foil. Why do you want it?If you really want to buy a 122 key "battleship" keyboard I suggest looking for a IBM Model F 122.
http://www.seasip.info/VintagePC/kb3270.html
Welcome to DT!
Welcome to DT!
- Chyros
Very unlikely magnetic reed, doesn't look anywhere near old enough. I suspect foam and foil, though it could also be dome with slider. The foam and foil switch is often regarded as one of the worst switches ever made.
- DT Pro Member: 0011
With a terminal keyboard, you can't always be sure that it could be connected to a PC. It could speak some arcane proprietary terminal protocol.
The foam provides a very mushy landing. It also deteriorates over time, so there is a risk of a keyboard not working.
I would not say that it is one of the worst switches ever made, though. If it hadn't been for the foam, it would actually be quite pleasant to type on and the keycaps are often double-shot moulded (but don't fit anything else...).
I once had a working foam-and-foil keyboard and I could not give it away because no collector wanted it. I donated only the foam pads to someone who was restoring an old system (Apple Lisa maybe, I don't remember).
- seebart
That's right if the foam is deteriorated due to it's age the whole keyboard becomes useless. Do yourself a favor and don't buy that.
rootwyrm
- Main keyboard: M13, AKB-625, 9000V2
- Main mouse: Steelseries Rival 300, WoW Wireless
One, that's a PC keyboard. It requires a special driver for the additional scan codes. That's it. It was specifically made so a PC could be used as a mainframe terminal, the end. Some of them are serial to ease the driver stuff, but it's not common in Keytronics.
But it's a foam-and-fail board, and one of the worst they made. $3.25? This thing isn't worth $0.32.
The indicator lights on the Caps Lock and in the corners of the Num Lock and Scroll Lock match Key Tronic foam-and-foil.
rootwyrm
terrycherry
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
Yes, it's Key Tronic foam and foil[(Tactile)Type1,(Tactile)Type1 LED] AT keyboardBattlefieldium wrote: What switches are these, im not having any luck on google. I found one for 325 USD on Ebay but it does not really specify the switches. And are these really that expensive?
I have one. Can sell it to you for half price including shipping fee.
