Hi all .
I currently have a https://www.amazon.co.uk/EC-Technology% ... B00R7NAFKI
I am very happy with the design and build quality however the DPI is just too low for a 4k screen in my opinion.
I have a Logitech Performance MX too and that thing is total and complete dogshit, i regret buying it but i was desperate and it was the only 1/2 decent thing in the local shop when my death adder died, so no logitech
With amazons black Friday stuff starting i was wondering if anyone had any experience with some of the cheaper "gaming" mice on amazon.
List of requirements
20-30 GBP
thumb rest if possible
high DPI (8200) for 4k
no logitech
not look too much like a gamer mouse.
no stupid shiny plastic
no wireless
accurate sensor ( unlike the logi i mentioned)
Looking for a high DPI mouse, ASAP for black Friday.
- need
Although this is wireless and might not have a high dpi, but for £9 that I've paid its pretty nice.
https://www.amazon.co.uk/Wireless-HAVIT ... Havi+mouse
- DT Pro Member: 0167
Thanks for the input, i found a mouse but i cannot post what one yet as i got 2 of them, one i will use one will be a part of something else .
It was just above my range but black friday made it around the lower of my range.
- hook
- Main keyboard: Matias Mini Quiet Pro
- Main mouse: Roccat Kone Pure
- Favorite switch: dampened Alps, Model F if no-one is around
I can warmly recommend Roccat. I have their Kone Pure, which is programmable and can be set up to 8200 DPI. I usually switch between 1600 or 3200, depending whether I’m using it on the actual desk or a on my armrest.
After I already had it for a while I tried a high-end Logitech (which would have been my other option) and I’m honestly happy I chose the Roccat.
Even the community-based FOSS Linux drivers work perfectly fine with it
…for your budget, I’d say go for a Kova (but not Kova[+]!) or a Kiro – Kova (7000 DPI) is an ambidextrous/symmetrical mouse and the Kiro (sadly only 4000 DPI) is a modular one, where you can add or remove extra keys on left and/or right side of the mouse.
- Main keyboard: Filco Ninja
- Main mouse: Logitech G502
- Favorite switch: Cherry Brown
The Logitech G502 is quite similar in pricing to the Kone Pure. Has a higher DPI of up to 12,000 but it is only for right handers.
I don't think you will go wrong with either of these, however you didn't mention what is your upper budget so we're only guessing here as to which mouse will fit your bill.
- hook
I think his "20-30 GBP" was meant as a budget. Although that is quite slim for a proper (even non-gaming) rodent.
Thanks guys i got one.
well i got two , for the bottom end of my limit.
I am using one, the other however...
- hook
Great to hear it! But don’t leave us hanging – what did you get? :3
- Main keyboard: Corsair k70 rgb rapidfire
- Main mouse: Razer DeathAdder Chroma
You may want to get a mouse with an optical sensor. That being said, the Razer Deathadder Elite is actually a pretty good mouse in terms of ergonomics and the sensor. You cannot go wrong with it.
