Failures and mishaps
ohaimark
Kingpin
29 Dec 2016, 19:59
I just found an Amazon listing for O-rings that touts a hilarious product image.
Yes, they put an O-ring on a rubber dome. Yes, that will probably prevent the switch from actuating.
paecific.jr
29 Dec 2016, 20:40
Oh the joys of Amazon.
Harshmallow
29 Dec 2016, 22:37
Look at those smexy pad printed legends though. Someone got a gold star in class for their scissor skills.
Elrick
30 Dec 2016, 04:12
They had to provide pics quickly for the listing as instructed by the owner/seller hence the poor person who had to use anything to show how and where the O-rings go.
It's alright for us aristocrats to poke fun at the "domers" but when you consider that is all they had in front of them and they needed the photos straight away, then you can forgive their ignorance.
They still showed how to attach the O-rings, which applies to every key-cap used :D .
keycap
03 Jan 2017, 00:17
What makes it even better is that it probably wouldn't even work with those o-rings on. Either it wouldn't do anything at all or it would render the key inoperable.
Lynx_Carpathica
07 Jan 2017, 23:40
This is just amazing, I have to silence my Ivory alps, so I'll get 101pcs xD
keycap
11 Jan 2017, 03:19
This is almost as hard to look at as that one manual for some old Alps board telling you to "glue keycaps to the switches", except the latter is, well, disastrous. And immoral. :x
