Lubing IBM model m/f springs
- Ir0n
- Main keyboard: IBM Model F107 / SSK
- Main mouse: logitech lift
I know there is some topics about this already so don't think I didn't already search or anything..just didn't want to necro.
From what I've read it seems teflon lube would be the best type to use?
I want to pick up a big bottle, or jug locally so I don't got to wait on shipping and such.
Where would one find Teflon lube? autozone, or lowes maybe?
Another question I have is do you soak them in the lube and wipe them clean, or just let them dry on their own?
Thank you!
Thank you!
- fohat
- Elder Messenger
- DT Pro Member: 0158
I did this once and stood them upright with a piece of cardboard covering the pivot plates ("feet") in front of (and another one behind) the springs leaving only a thin "shoulder strip" exposed on either side of the spring base. Then I sprayed the vertical springs with a dry teflon lube and let them dry thoroughly.
- Ir0n
You can get it in a spray? Lol This option sounds cleaner than what I was going to try.fohat wrote: I did this once and stood them upright with a piece of cardboard covering the pivot plates ("feet") in front of (and another one behind) the springs leaving only a thin "shoulder strip" exposed on either side of the spring base. Then I sprayed the vertical springs with a dry teflon lube and let them dry thoroughly.
I'm going to look for some tomorrow. ;o
Thanks guys.
- fohat
- Elder Messenger
- Elrick
- Main mouse: MX518
Just out of interest, how long will this lube last in any Model-M or F keyboard
- fohat
- Elder Messenger
I have no idea, and don't really care. The springs were not lubed originally, and I mostly did it for a measure of corrosion control. My guess is that where the coil that hits the barrel wall will wear off quickly and the areas that never make contact will keep their coating almost indefinitely.
- Mr.Nobody
- Main keyboard: IBM Model M/F
- Main mouse: Lenovo Big Red Dot
I had one lubed accidentally by its original owner, it becomes quieter and softer IMHO, it had lost M's characteristics.I sold it not long after. I don't think it's necessary to lube the M, the original design is good enough and this is proved by time, I think the longevity of Ms will surpass ours.
- ramnes
- ПБТ НАВСЕГДА
- Main keyboard: KMAC LE
- Main mouse: Zowie AM
Just get yourself a IBM model M SoftTouch.
- fohat
- Elder Messenger
I see that clikcykeyboards has updated their web site.
Anybody who wants one of these should pounce on it, they didn't make many and they rarely turn up for sale.
Once I bought a home-made botched "Soft Touch" modification on ebay (as "not working - parts only") for very cheap and it had been disastrous. But it was an easy re-build (I threw the flippers into the garbage and de-greased everything else thoroughly) and I got a perfectly good ordinary M by using my spare flippers.
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Ah, the ol' soft touch mod.
workshop-f7/ibm-soft-touch-model-m-mod- ... 14302.html
I still stand by everything that I said six months ago! Maybe I'll try it out finally, on a key switch tester made from a Model F barrel, a Model M flipper, and a spare key.
The trick is to lubricate all the springs *equally* for a consistent feel.
- Elrick
- Main mouse: MX518
What I worry about is the effect of Gravity upon any lubricating substance here. By nature it shall all pool down towards the base and spill out everywhere.
Hence my earlier question about longevity, it shall eventually end up going elsewhere like an unwelcomed guest
- fohat
- Elder Messenger
I think that the original Lexmark grease was stabilized and would remain in place as long as the environment was reasonably moderate.
