I want to replace my stock V60 LEDs with different color ones, yellow/amber specifically to match my switch color. I'm not sure what size LED this is:
Thanks for the help.
Thanks
Yea, its off to the side, its Alps so its not in the switch like Cherry MX. Also wanted to change the right one which is under the right shift but that should also be fine since its off to the side as well.Matt_ wrote: Good point. That's why some builders prefer 1.8mm LEDs:
They have the same footprint (leg spacing) as 3mm LEDs but are much shorter, so they won't collide with keycaps, even thicker ones.
edit: I've just seen your build pictures, if you only need to change the capslock LED a 3mm one should be perfectly fine.
