Anywhere that does (custom) Top & Front printed keybaps
variable
25 Jan 2017, 03:34
Is there anywhere that prints custom top & front printed keycaps (such as those in the picture I've attached)? I know it's a long shot, but wanted to ask.
Thanks,
-Eric
zslane
25 Jan 2017, 03:40
Signature Plastics can do that, but one-off keysets are prohibitively expensive.
t8c
25 Jan 2017, 10:52
Try DecentKeyboards on etsy or Idea23 on reddit!
Laser
emacs -nw
25 Jan 2017, 11:08
Also here: http://www.wasdkeyboards.com/index.php/ ... ngles.html
I believe if you buy a new keyboard from WASD, you can also upload an *entire* custom layout based on a template to use for that keyboard's keys text/colors. If you include the actual keyboard in the price, it may be way cheaper than the separate key printing service.
variable
26 Jan 2017, 18:12
Laser wrote: Also here: http://www.wasdkeyboards.com/index.php/ ... ngles.html
I had asked WASD but they said they do not do Front printed keycaps unfortunately. I did find Max Keyboards, and they seem to be able to.
Return to “Marketplace Help”
