Help with Keyset please
ZepeliN
09 Feb 2017, 18:14
Hi everyone,
I'm the owner of a Leopold FC980M, i have problems to find keycaps and keyset for them.
The keyboard have 98 keys , but my biggest problem is the size of Alt and Ctrl of the right, because have the same size like a normal key (alphabetic), and the right shift is smallest like the usual iso or ansi. Thanks for your help
PD: Sorry for my english
ZepeliN
09 Feb 2017, 19:30
:( help please
zslane
09 Feb 2017, 20:58
As far as I know, the only place you're going to find keycap sets with special keycaps like that is from group buys that offer a Tsangan or Specialty kit. You'll want to lurk on GeekHack.org's Interest Check forum so you can learn what custom keycap sets are heading for a group buy.
duynguyenle
10 Feb 2017, 00:10
There's a couple of GMK GBs currently running that have the appropriate kits for your situation. Of course waiting may not be desirable to you, so if you can deal with blank caps, it's probably OK to get this: https://www.aliexpress.com/item/NPKC-Bl ... d73095d281
ZepeliN
10 Feb 2017, 14:39
Thaks for yours answers...
