The ADB cable I got for my Japanese AEKII is yellowed, can retrobright fix this? Never done a cable before. I would have to tape off the metal ends and wrap it with clingwrap.
Well, that's why I would tape off the metal ends completely with tape.orihalcon wrote: I believe retr0brite does work with most cables, but could potentially rust out anything metal, so not sure that's worth risking. Personally would just get a different ADB cable. Original apple ones aren't very expensive I don't think. You can also use cheap S-Video cables too, but unlikely to be coiled if that is what you are going for.
