I'm using Capsense 0.9.0 with an F107 and I want to Cut, Copy, Paste, etc., with one assigned key. It doesn't seem to work; however, assigning alpha-numeric keys works fine.
Also, I cannot figure out how to set Macros. The pdf on http://downloads.cornall.co/ibm-capsense-usb/ didn't seem to help with this.
Please help. Thank you!
Capsense help
- just_add_coffee
- Main keyboard: Model F AT, Batwing Ergodox
- Main mouse: Microsoft Trackball Explorer 1.0
- just_add_coffee
I cannot figure out how to make the macro. The first image above is what I'm looking at and nothing that I've tried seems to work.
- just_add_coffee
Bueller
- just_add_coffee
Is it possible to use another firmware? Maybe something that's been updated within the last 2 1/2 years?
- just_add_coffee
I finally got it.
As Ratfink said, you've gotta assign a key to either Copy, Cut, or Paste. I did that in Column 13. Next, in the Macros tab, select either Copy, Cut, or Paste in the Trigger on dropdown menu and leave everything else at the top alone.
The tricky part is bottom section with Command and Value. You have to select Assign Mods and then either L Ctrl or R Ctrl, press +, select Press, and finally, c and C (or x and X, or v and V). Not exactly the most intuitive interface ever devised. And xwhatsit never got around to including any instructions on his site regarding configuring macros.
And thank you to everyone here who helped, which includes Ratfink and no one else. Probably should've asked on /r/mechanicalkeyboards or GeekHack instead.
