Prism N7 Portable - SMK keyboard with Alps switches
snuci
Vintage computer guy
08 Apr 2017, 20:00
I got this Prism N7 ATX portable computer recently to image floppy disks. It's a good computer with a Pentium II 233MHz CPU and plenty of disk/memory and a 16 bit ISA slot plus USB (which is really great for transporting disk images). It is a bit rough but I bought it for use and not collectability.
The keyboard is interesting because I haven't come across an SMK keyboard with Alps switches unless it's really NOT an SMK keyboard or these are clone Alps switches with "Alps" molded into the switch tops. This particular keyboard absolutely looks like an SMK keyboard from the PCB board and has a QC sticker that has SMK on it. The Alps key switches look like Alps. Is this out of the ordinary for the era or are the switches clones?
Here are some pics.
Prism N7 - keyboard front
Prism N7 - keyboard front.JPG (262.04 KiB) Viewed 5159 times
Prism N7 - keyboard back
Prism N7 - keyboard back.JPG (199.33 KiB) Viewed 5159 times
Prism N7 - top cover removed
Prism N7 - top cover removed.JPG (356.16 KiB) Viewed 5159 times
Prism N7 - keyboard mechanism back
Prism N7 - keyboard mechanism back.JPG (483.71 KiB) Viewed 5159 times
Prism N7 - Alps key switch
Prism N7 - Alps key switch.JPG (286.49 KiB) Viewed 5159 times
Prism N7 - key caps
Prism N7 - key caps
Prism N7 - key caps.JPG (290.68 KiB) Viewed 5159 times
Prism N7 - spacebar Alps switch
Prism N7 - spacebar Alps switch.JPG (242.73 KiB) Viewed 5159 times
Prism N7 - integrated mouse pad
Prism N7 - integrated mouse pad.JPG (329.72 KiB) Viewed 5159 times
Prism N7 - keyboard controller dated 13th week of 1997
Prism N7 - keyboard controller dated 13th week of 1997.JPG (310.13 KiB) Viewed 5159 times
Prism N7 - keyboard markings
Prism N7 - keyboard markings.JPG (297.36 KiB) Viewed 5159 times
Prism N7 - SMK Quality Control label
Prism N7 - SMK Quality Control label.JPG (264.91 KiB) Viewed 5159 times
Prism N7 - portable computer
Prism N7 - portable computer.JPG (237.2 KiB) Viewed 5159 times
zslane
08 Apr 2017, 20:04
We used to call those "luggables".
snuci
08 Apr 2017, 20:06
Trust me, I've got "luggables". This one is light compared to those :)
EDIT: But you are technically correct. It just seems too new fir me to consider it a "luggable" that you really need to "lug" around ;)
08 Apr 2017, 21:49
I always thought that Eleen was a nice name …
SMK in this case denotes Strong Man, not Showa Musen Kogyo.
The switches are Forward SKBM White "simplified Alps", back when they were still Alps branded.
snuci
08 Apr 2017, 23:35
Ahh... Thanks Daniel. I saw "Strongman" on the controller but have never heard of them.
08 Apr 2017, 23:59
Fairly infamous — they made many older Filco keyboards as well as the Matias Tactile Pro and Tactile Pro 2.0. However, both Diatec (owner of the Filco brand) and Matias abandoned them for Costar, and shortly afterwards Strong Man went bust. Amongst other sins, Strong Man called any unbranded switch a "Strong Man" switch, convincing Matias that Forward SKBM Grey (following the termination of the use of the Alps branding) used in the then-new TP2 was a Strong Man product (where in reality the TP had already transitioned to grey switches without Matias noticing); they also called four-tab clones "Strong Man" switches, even though they just appear to be regular Himake switches. Nan Tan did the same: the "N" in the -EN keyboards appears to denote Nan Tan switches (there's a brochure scan here somewhere demonstrating their use of so-called "Nan Tan switches") — yet these too seem to just be Himake. (Shared tooling may account for those, but not for Forward's switches.)
Strong Man also appear to have commissioned a four-tab clone that takes Cherry keycaps, but this seems not to have gone into production.
Strong Man keyboards often have "SMK" in the model number, which is easily confused with SMK in Japan.
Harshmallow
10 Apr 2017, 18:03
Nice portable PC Snuci! I just picked up a complete IBM P70 and a Panasonic/Matsushita FT-70 'Exec Partner' with built-in printer over the weekend near Windsor.
There's actually a Strongman keyboard on Ebay right now...I believe it's been there for a while now (overpriced):
http://www.ebay.com/itm/IBM-PC-AT-Stron ... Sw32lYrf5H
vsev
14 Apr 2017, 07:32
Like very much this layout, nice catch snuci !
Shihatsu
24 Apr 2017, 10:37
The almost perfect Layout here - bottom row with all needed keys + iso. This bottomrow on a 96 (97, that is) is my dream.
24 Apr 2017, 12:23
Sweet zombie Jesus that layout is awesome
24 Apr 2017, 16:04
Best looking luggable I've seen in a long time. Nice work as usual snuci! I'm sure this cost a fortune back in the day.
