I've posted a curated list of the best keyboard layouts for comment/criticism/etc. Constructive criticism welcome.
The scoring was done with a varied corpus using Patrick's KLA with a modified scoring system, developed by Den (shenafu.com).
Focus is on English and programming/technical. Have not even thought about non-English tests yet.
The summary table combines best results from ANSI and assorted ergo layouts.
http://www.keyboard-design.com/best-key ... youts.html
If you want to play around with the database of results, follow the links here:
http://www.keyboard-design.com/best-layouts.html
All the layouts (more than in the curated list, including 'dev' versions) can be found on my fork of Den's fork of KLA, here: http://kla.keyboard-design.com/#/config
Rest of site is work in progress
Cheers, Ian
