The odd keybind thread? How to printscreen on an IBM xt keyboard???
Wingklip
20 May 2017, 10:30
I found the printscreen key but unfortunately, it is tied in with the asterisk key. Any combination of shift or control or alt all seem to not work, Help please :)
mana
20 May 2017, 12:36
I assume that you are using a Soarer's converter (rather than using the XT on, well, an actual XT computer).
If this is the case, you may have to just reprogram the print screen key to a macro (i.e. shift + prtsc) if it's not already working. Soarer already has included how to do so in his documentation. The code for it is "PRINTSCREEN" oddly enough.
