keycap joint getting stuck
hi i recently bought a hyperx alloy keyboard. all keys are good but when i press tab key it gets stuck on the edges of the switch. i dont know if that makes sense. the square edges when you press into the switch gets caught by the cross on the keycaps. its fine when i press it directly above, but you cant always press it like that since its on the side. i was thinking maybe i could shave off some bits off the outer side of the keycap cross. has anyone encountered this problem?
